Results 1 to 10 of 16
Thread: Dammit! Suspect water pump!
    Brissy! No flannos here!
    Dammit, I am getting a pool of coolant under my D2 most mornings - maybe 1/3 or 1/2 cup. A quick look seems to indicate the coolant coming from higher up the left side of the engine. I'll bet it's a water pump!
    Being currently in the middle of a move to Melb and living in temp accommodation, I have no tools or even a place to work on it until I secure an apartment and have my stuff delivered.
    Even then, I only brought a basic tool kit with me, so I may just be able to do it in a high rise car park.
    I may need to call on the generosity and kindred LR spirit of you Melb folk in the next couple of weeks if anyone could assist with a workspace and a few tools maybe. I am currently in temp accom in Laverton in the western burbs.
    Time to start sourcing a pump.
    Ralph
    May 2010
    brighton, brisbane
    Don't mean to be too Sherlock Holmes on this, but.... if it is the water pump, you will see leakage from the tell tale hole, on the bottom of the pump. Is the leakage the colour of your coolant. You would know the air conditioning drain leaks condensation to ground. Normally on the right hand side, but many people shift it to the left, so it doesn't drip on the front Carden shaft, creating a problem there. Does your coolant overflow tank level drop equal to your fluid drop under the vehicle. Simple things first. Bob
    I’m pretty sure the dinosaurs died out when they stopped gathering food and started having meetings to discuss gathering food
    A bookshop is one of the only pieces of evidence we have that people are still thinking
    Western Victoria
    Laverton! Yeah, I'm sure there will be a few around who would be able to help.
    I can't over the next couple of weeks. After that, I have a few tools.
    St Helena,Melbourne
    4.28 MB
    I'm 25 or so mins away have tools and time on my hands, can still assist albeit on one leg.
    Sent from my GT-I9300 using AULRO mobile app
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Nov 2014
    Nirvana near Albany W.A.
    Quote Originally Posted by bob10 View Post
    And i dont mean to be Watson , but Air con drains on both sides I,m pretty sure , Bob
    Ralph1 malph, hopefully someone has fitted a jubilee clamp and it has just come loose. You can always try optimism.
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by discorevy View Post
    If the aircon drains are leaking coolant he has serious problems.
    1974 VW Kombi bus
    Nov 2014
    Yeah , would probably indicate a heater core , but can't see where anyone has mentioned this on this thread...........
    Anyhow , Ralph 1 Malph have you had a closer inspection yet ?
    hopefully might be just a loose jubilee clamp on bottom hose passengers side.
    Thanks All,
    I have secured an apartment and hopefully move in this weekend. Still may need to visit someone with 'space' tho.
    I have with me in the car a set of screw drivers, a 3" shifter and a pair of Suzuki pliers so I have yet to conduct a detailed look.
    I have pulled the plastic cowling/shield from underneath behind the wombat bar and shone a torch up there. I can only see the dribble marks about half way up the block as my torch is also sub par. I did manage to rule out the lower hoses at least the obvious ones.
    When my tool kit arrives, I'll pull the air intake and have a good look from the top in good light.
    Yes, I would surmise that the amount lost is similar to the amount I top up the overflow reservoir with.
    Ralph
    Bacchus Marsh Vic.
    If your not going to Wandin Sunday and want to wander up my way yell out.
    All the work is done in the drive but we can at least have a look and identify where the leak is.
    I've got clamps here if that's all it is.
    Cheers, Kyle
    The Good Oil.
    When did you last visit?
    Western Victoria
    Quote Originally Posted by alien View Post
    I've got a cooling system pressure tester if you think that would help.
