Results 1 to 3 of 3
Thread: d2's not poo.... thoughts from the loo
    Nov 2014
    Nirvana near Albany W.A.
    Is your coolant at a loss, could be time to give a toss
    Is there a flash upon your dash, its messing with your head
    could well be that xyz.
    If your airbags down ,making you frown,you don't want to change it for a coil
    have a look on the good oil....before the blood begins to boil
    does your car have an FPR , does it have a little leak... you CAN fix it before you freak.
    replacing your head ?. then don't see red... but plastic dowels are only worth whats in my bowels.
    These probs and more are quite a chore, makes you think your cars a whore.
    TD5's are nice to drive but worth lots more when kept alive.
    So don't despair ... pull up a chair. you can fix it all tomorrow.
    Then with a grin upon your chin ,you'll have a win ...
    But only if you've checked out AULRO
    mmm .... sounds better in my head . as a poet I make a good mechanic... oh well , back to the spanners
    Sep 2012
    Adelaide Hills
    i think the heat has got to him
    Sep 2010
    adelaide
    drinking in the loo. well efficient at least
