Results 1 to 6 of 6
Thread: Part Numbers for O2 Sensors & MAF Sensor
    Jan 2015
    DarwinNT
    G'day all,
    Can anyone please help with the part numbers for the O2 & MAF sensors for my '04 D2 V8 4.0? I believe she's one of the last of the D2's.
    I have the VIN number if that helps.
    Cheers!
    Jul 2014
    west of Transylvania
    Hi, here you have the MAF (nr 6) Allbrit.de - Ersatzteile f?r LAND ROVER & MG ROVER , and here the O2 sensors(nr 3) Allbrit.de - Ersatzteile f?r LAND ROVER & MG ROVER, goodle out the part numbers to make sure they were not superseded and if you need any other parts click on "Back to navigation" at the top and select what you want
    Jan 2015
    DarwinNT
    Mate, that site is amazing!
    Found the part numbers, jumped on eBay and got everything (2 x O2 & 1 x MAF) for $360. Considering I was quoted "About $400" for one O2 sensor, I'm well pleased!
    I got this stuff through Jag Prestige Spares' eBay shop. Gave them a ring to ask a couple of questions, and apparently they wreck Discoverys on a regular basis and also hold a stack of new stuff in stock - very helpful mob.
    The trick with owning a Disco seems to be "Shop Around". I'm pleasantly surprised to find that parts are actually quite cheap; especially compared to Japanese 4WD's. It's incredible what's available on eBay..... I just didn't expect to be able to get parts via that method!
    Nov 2014
    Nirvana near Albany W.A.
    Hi Dave , just be aware that the link sierrafery gave for the maf was for a diesel , the part number for v8 should be something like err7171
    Not mhk100620 or 5 WK 9607
    O2 sensor numbers were correct
    Jul 2014
    yes, sorry about that, they are near each other and it seems i clicked on diesel instead of petrol Allbrit.de - Ersatzteile f?r LAND ROVER & MG ROVER
    Jan 2015
    DarwinNT
    Quote Originally Posted by discorevy View Post
    Yeah, thanks mate. I realised that was probably the case and double-checked the correct number with Jag Prestige Spares before I ordered
    That website's a good resource, isn't it?
    Where you have two part numbers listed with the same code, but, with one having an appended "Z", does that indicate aftermarket (with the Z) and genuine (without)? The price differential would probably suggest that that is the case ......
