6X6 onboard air system
Has anybody done an onboard air system on a Perentie 6X6 yet. I am planning to do so shortly and would appreciate if anyone could post up some details if they have done one. Even with an aircon compressor fitted there is heaps of room to fit a York compressor in the engine bay. My plan is to fabricate a bracket that fits to the CAV generator bracket and will hold the York double piston compressor which will be driven off the double row pulley on the alternator. I will have to get my a into g shortly and post up some pics of my 6by - been pretty slack I must admit. Some other mods I plan on doing is fitting the aircon setup, an extra large fuel tank and a water tank and 2 more spares in the centre section of the massive space under the alum tray. Plus the air tank and 2nd battery on the passenger side. Plus I also have to manufacture a Hayman Reece style towbar to put on the rear as well as keeping the pintle assy. Plus I have a 1300kg palfinger to mount in the front centre of the tray so I can lift 44's of fuel onto the back without blowing a poofoo valve. Also have extra gauges like pyro, boost, tacho and oil pressure/temp and air pressure to fit.
Will probably have to manufacture a new binnacle to fit them all. So much to do!!!!!
Cheers......Brian
1985 110 V8 County
