                                                17th February 2015, 08:36 PM
			Axle upgrade on a 56 short
					Looking to upgrade diff centers and axles on my series 1.
 I have a number different centers,lockers and 4 pinion, 24 and 10 spline stuff kicking around from rangie projects. So it's just finding axles to suit. Do Hy Tuff eng or other manufacturers make axles to suit series 1 front and rear
 Sent from my iPhone using Forum Runner
                                                17th February 2015, 08:39 PM
					you can ring barry at hi tough, he's in the book and very helpful.
  Safe Travels Safe Travels
         harry
                                                17th February 2015, 08:47 PM
					That was going to be tomorrow's job. If not I will make some up myself
                                                17th February 2015, 10:57 PM
                                                #4
					As you are going to modify the 86" anyway, I would change both the diff housings over to the wider Series 2A SWB ones and that lets you choose from a lot larger selection of axles.
 The wheels still sit under the guards and the extra 3/4" of space between the inside of the wheel and the spring gives a better turning circle.
 Good chance to upgrade the brakes to 11" ones out of the LWB at the same time.
                                                18th February 2015, 07:13 AM
                                                #5
					Ah thanks for that idea, I will look into that as well
