Results 1 to 10 of 18
Thread: Special For AULRO members only TF930 Code Reader
    Vendor
    Subscriber
    Jul 2012
    Tecoma Vic
    We have a couple of Terrafrima TF930 code readers at a AULRO member special price of $300! and $14.60 express post anywhere in Australia.
    We have been asked for them so here they are. 1st in best dressed get them
    This is exceptional value for a tool that reads and clears codes. and Multi vehicle.
    Note, contrary to all the talk, they are a reader and resetter, they do not write fuel maps or program.
    They' ll be on ebay for $330 so be quick.
    It says Discovery from 2002 on box , but it also does Discovery 2 1999 on
    Defender should be TD5 on inc Puma. (1997 is incorrect on box as that would be 300 Tdi)
    Carsoft Multi-system Scanner i930 for LandRover:
    i930 Multi-system Scanner supports full system diagnosis. It’s a powerful DIY tool, test modes include: CANBUS, ISO9141, KWP2000, J1850 etc.. It enables technicians to accurately diagnose complex problems.
    Eight Super Advantages:
    1. The fastest full color, 2.8” TFT 320*240 pixels
    2. USB 2.0 High Speed Upgrade
    3. Support Multi-language
    4. Read & Clear DTCs
    5. Read Date Stream
    6. Silicone keys with great customer experience
    7. Full System Diagnosis
    8. Diagnose Single Brand of all Models ( OBDII-16 DLC )
    Features for Landrover
    • Read DTCs
    • Clear DTCs
    • Read live data stream
    • Single Brand of all Models ( OBDII-16 DLC )
    • Full system diagnosis
    • Upgrade via USB 2.0
    • Multi-language
    OBDII function:
    1. Read Codes
    2. Erase Codes
    3. I/M Readiness -- I/M Readiness indicates whether or not the various emissions-related systems on the vehicle are operating properly and are ready for Inspection and Maintenance testing.
    4. Data Stream
    5. Freeze Frame -- When an emission-related fault occurs, certain vehicle conditions are recorded by the on-board computer. This information is referred to as freeze frame data. Freeze Data is a snapshot of the operating conditions at the time of an emission-related fault.
    6. O2 Sensor Test -- This option allows retrieval and viewing of O2 sensor test results for most recently performed tests from the vehicle’s on-board computer.
    7. On-Board Monitoring -- This function can be utilized to read the results of on-board diagnostic monitoring tests for specific components/systems.
    8. Evap System Test -- The EVAP test function lets you initiate a leak test for the vehicle’s EVAP system. Before using the system test function, refer to the vehicle’s service repair manual to determine the procedures necessary to stop the test.
    9. Vehicle Information -- The option displays the vehicle identification number (VIN), the calibration verification number (CVN), and other information of the test vehicle.
    10.Retrieve generic (P0, P2, P3, and U0), manufacturer specific (P1, P3, and U1) codes and pending codes
    11.Turn off Check Engine Light (MIL), clear codes and reset monitors
    12. Read live PCM datastream
    13. Support CAN (Controller Area Network) and all other
    14.Multilingual menu and DTC definitions- English, Spanish, and German, etc
    15.Read pending DTCs
    16.Read permanent DTCs
    17. DTCs search
    18. Supports all the OBDII/EOBD test modes include: CAN, ISO9141, KWP2000, J1850 VPW and J1850 PWM.
    19. Works on all 2001 and later OBDII compliant PETROL European vehicles
    20. Works on all 2004 and later OBDII compliant DIESEL European vehicles
    21. Works on all 1996 and later OBDII compliant US and Asian vehicles
    22. View & Graph Live Data in Color Graphing and blazing fast refresh rate for better graphing and live data readings.
    23. Comprehensive Help, Including OBD Parameter, Mode Explanations & More
    Vehicle coverage:
    • Freelander
    • Freelander
    • Defender
    • Discovery II
    • Discovery III
    • Discovery 4
    • Range Rover Sport
    • Range Rover
    • Range Rover Evoque
    System coverage:
    • Engine
    • PCM
    • TCM/Gear box
    • ABS
    • RCM/ SRS/ Airbag
    • ICCM/IP
    • RLCM /Air Suspension
    • BCM/BODY
    • HVAC/Air Conditioning
    • VDCM
    • SASM/Steering
    • TPM
    • PBM
    • Parking assist
    • Parking Aid
    • AHCM
    • VICM/Security/Immo
    • DDM
    • DSM
    • PDM
    • PSM
    • ATCM
    • TCCM/Transfer Box
    • ADCM
    • SCM
    • DRM
    • Rain Sensor
    • GSM
    • Light check/Lighting
    • OCS
    • HCM
    • ICM
    • KVM
    • Television
    Specifications:
    A) Display: 2.8” Color screen , 320 x 240 pixels display with contrast adjustment
    Operation Temperature: 0 ℃ -- 50 ℃
    C) Storage Temperature: -20 ℃ -- 70 ℃
    D) Power: 9V -- 18V
    E)Operating current:100mA@12V(Typical)
    F)Power consumption:1.2W(Typical)
    G)Dimension:121mm*86mm*26mm(LxWxH)
    H)Weight:300g
    Contents:
    • Hardcopy User’s Manual
    • 6-foot OBD II cable
    • USB cable
    • Nylon carry case
    Support Multi-Language:
    Below languages are now available:
    • English
    • German
    • Spanish
    • French
    • Portuguese
    • Russian
    • Dutch
    How do I become a special member?
    Vendor
    Subscriber
    Jul 2012
    Tecoma Vic
    I have made you one.
    Free Again Thanks Dan
    Im special
    Vendor
    Subscriber
    Jul 2012
    Tecoma Vic
    Quote Originally Posted by rangieman View Post
    Im special
    Yes your really special, they even have a bus to pick you up Chris
    and your my Special Friend that i talk to when I'm all alone
    They don't seem to cover 1974 RRC's.
    cheers, DL
    Bairnsdale enjoying the rural view no rooftops to see here
    roflmao
    have a good one :D ken :wasntme:
    MY07 L320 RANGE ROVER SPORT MORE GOODNESS TO COME
    MY03 D2A TD5 EXTRA GOODIE ENHANCED :D now parting from life
    1996 D1 300TDI GONE
    08 ford ranger c/c
    WRECKING DISCOVERY 2
    PM ME FOR WHAT YOU ARE LOOKING FOR
    the 97 defender will be the NAS spec one with the V8,central,immobiliser and alarm.
    Vendor
    Subscriber
    Jul 2012
    Tecoma Vic
    Quote Originally Posted by 350RRC View Post
    cheers, DL
    Sorry There's very little stuff available for the vintage landys no OBDII
    Vendor
    Subscriber
    Jul 2012
    Tecoma Vic
    Quote Originally Posted by Outback 1 View Post
    roflmao
    Don't you laugh Ken, your my other special friend
