Thread: AULRO Stickers
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    AULRO Stickers
    Becoming available soon!
    Price will be $6.60 each plus postage
    I use registered post on all items so it is trackable. (cost is about $7.50 per set of stickers)
    You can have your name or favorite quip (there will be a maximum letter count) and it must be G rated.
    printed on clear film and undercoated print so it has depth (what you see in grey will be clear) making them much easier to fit then previous versions!
    same size as earlier editions so they fit on the rear glass on a 110...
    single lettering is about 12mm high 2 lines about 5mm high for each line
    i need a minimum order of 50 units per run.
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    time is nearly on us for another run of stickers!
    i just have to confirm pricing and setup the store for the names / custom text options.
    be back shortly!
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    Sticker Run 2017
    STICKER RUN 2017
    AULRO Layered Sticker Custom
    $10.75 ea
    Multi layered high quality vinyl sticker with your name or caption below as per the example "DULLBIRD" in the example picture.
    They are 125mm wide so they fit the rear side window of a Defender or in a tac plate holder.
    There is room for one line of text with either your name or a "G" rated slogan with a maximum of 26 letters numbers or spaces.
    I can ship upto 6 stickers with the same text per pack and postage is $5.50 per pack (Registered Mail).
    Orders will be taken till the end of September and then the order placed with the supplier and i anticpate we shall be able to ship them in the last week of October or first week of November 2017.
    you can start ordering yours now
    ORDER ONLINE
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    orders are now closed
    well over 150 orders received
    they will be sent to manufacturing this week...
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    I am told the stickers will finally be delivered to me tomorrow if all goes to plan...
    Once we get them they will be mailed as quickly as we can get them out.
    Instructions for fitting them below
    Sign industry standard
    Installation of stickers
    You will need:
    Metho
    Clean rag (something that won't leave lint)
    Measuring tape or ruler
    Masking tape
    Stiff plastic card with straight edge, like a credit card.
    (Signwriters use application squeegees )
    Method
    1. Clean surface the sticker is to be installed. Remove all marks, grease, oil and foreign objects. Give a final wipe with metho and wait a few seconds to dry.
    2. Place your sticker on a flat surface and run over the top clear tape to make sure all lettering is adhered to clear application tape.
    3. Place sticker on the substrate​​ you want to install it to, with backing paper still on.
    4. Use a ruler to position it where you want it to go
    5. Use masking tape to go across the top of sticker and substrate. This holds it in position. Try to get half the tape on the sticker and the other half on the substrate.
    6. Flip the sticker over. The tape will hold in place.
    7. Peel the paper backing off.
    8. Flip sticker back over, avoiding touching the surface and keeping light tension. Hold it as close to the surface as you can without touching.
    9. Use your card, starting from the tape at the top and apply pressure. Work your way down the sticker
    10. Remove making tape.
    11. Remove clear application tape.
    If you have any bubbles in the vinyl, you can leave in the sun. Heat helps remove them. If the bubbles are still there you can pop with a pin and smooth out.
    and a little movie for you
    AULRO Stickers.mp4
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    Thumbs up
    FYI
    stickers are packed and going out on the next mail run
    as usual there has been a hiccup or two but mainly with logistics.
    those that made multiple orders should receive their stickers in one pack but they are going express post so you get some value for your money spent.
    don't ask, it wasn't pleasant...
    sorry they are a week late but I did all I could to get this out as close to on schedule as possible
    enjoy!
    Oct 2003
    Montrose, Vic.
    Mine arrived today thanks Dave.... look great 😊
    Mark
    2003 D2a TD5...gone...
    2000 D2 V8...gone...
    https://bymark.photography
