Results 1 to 6 of 6
Thread: 4BD1 injection pump leak
    Feb 2013
    Sunshine Coast
    Today I took the Perentie to get a QLD safety cert so I can register the old girl in her new home state. Unfortunately the mechanic I took her to picked up on a minor diesel leak the IP has coming from the throttle control lever. I'd noticed the leak before and tightened the nut on the lever and the leak had stopped, but now that it has returned it may need a proper fix. Unfortunately I can't access the vehicle to take a look until tomorrow and I'd like to go with an idea of how far up the proverbial creek I am and whether I have a paddle.
    Digging through the EMEIs, I've found this paragraph and picture.
    Which tells me there is an oil seal around the throttle control lever shaft; question is, is it installed from outside the pump case or inside? Now I really might be asking too much, but does anyone know the dimensions of that seal?
    Hay Point
    I'll get back to you tomorrow with some details if we don't get blown away overnight.!!!!
    Cheers......Brian
    1985 110 V8 County
    The oring for the stop control is listed as
    o ring, neoprene rubber 14.5mm od 10mm ID with part number so266/9813919060 or z5394/9813919060
    the seal for the accelerator shaft is
    seal, oil, 20mmod single lip tapered rubber cad plated metal case spring insert in rubber 12mm tapering to 9,4mm ID pn so266/5157290190 or z5392/5157290190
    from memory both can be changed externally if you are tooled up appropriately and have just the right amount of luck
    Feb 2013
    Sunshine Coast
    Thanks to you both, that's exactly what I need to know. Hopefully Marcia doesn't give you too much of a hard time tonight Brian
    Hay Point
    All good mate, we missed the bullet luckily. Went to the south of here at the last minute.
    I see Dave has supplied both the part numbers you need. And I can confirm you can change them in situ externally.
    Cheers......Brian
    1985 110 V8 County
    Feb 2013
    Sunshine Coast
    Seal reseated; thankfully access isn't difficult. It seems to be holding for now but a replacement seal has been ordered just in case. Seems the culprit was the nut holding the throttle plate onto the shaft working loose and the resulting movement of the shaft disturbing the seal. Sorted now.
    Matt
