Results 1 to 6 of 6
Thread: Clutch thimgybob
    Jan 2014
    coes creek
    Clutch thimgybob
    So sorry for the blonde question but what is this i know it has to do with the clutch but just wondered if it had a special name as its not like any of the clutch set ups ive seen
    cheers James
    ps sorry for being so stoopid
    clutch bit
    Quote Originally Posted by jamesnedtaylor View Post
    cheers James
    The item is a "thingammybob".
    Clutch slave cylinder (266694), clutch slave cylinder support bracket (509856,561242,561922, or 561762), shaft and operating lever for clutch (273077, 537603, 544980, or 537603) plus various other small parts.
    Where multiple part numbers are given, the part depends on which engine and which engine suffix. See parts book.
    Jan 2014
    coes creek
    Thanks John
    Aug 2010
    Sunbury, VIC
    I woul strongy recommend using the factory sleeve and pins to conect this to the gearbox. There is a huge amount of stress on those items when the clutch is pushed in and a bit of pipe and a couple of bolts may work for a short amount of time, but they will either snap or wear quickly giving you a soggy feeling clutch with lots of play in it.
    Jan 2014
    coes creek
    I have a normal set up on mine just wanted an id to give away thanks though
