Results 1 to 3 of 3
Thread: Jerry Can Holders
    Mar 2009
    NSW Mid North Coast
    Jerry Can Holders
    I am thinking of fabricating a jerry can holder to take 2 jerrys each side (similar to an RFSV) instead of the standard 1 on my FFR.
    I have studied my one and it is approx. 350mm x 170mm, it is made from 100 x 3 flat bar bend around to form a rectangle and welded, then stitch welded to the base which I assume is 3mm plate. It is fixed to the vehicle using 2 bolts and a bracket to the end of the rear chassis cross member a couple of smaller bolts to the body and a self tapper/ metal thread screw to end of the tiedown lifting bracket.
    Does the FRSV one have any additional fixings, bracing or support?
    Could someone please post some detailed photos of the RFSV type?
    Are there any design drawing in existence of either type?
    Canbeera
    The base has a cut out to access the lifting ring fixings.
    Mar 2009
    NSW Mid North Coast
    Thanks Carzee
    I dont airlift mine all that often so probably wont need the cut out.
