Originally Posted by
Mercguy
This is interesting. I had not thought of this as a viable option.
Apart from welding the BJ mount, what other fab is req'd to fit them in... spring perch mods etc. or does everything line up exactly?
You can change the spring mounts or use 80 series springs in the front and change the shock towers to the ones with twin shock capability and use those mounts to the standard GQ shock mounts.Other than that the front is a straight swap.
'assuming' a GQ front diff was fitted to the RRC, would it then be possible to use the superflex arms or is that still a no-go because of some idiosyncratic RRC thing? For some reason superior do not do a superflex for the RRC but will do it for Disco 1 ?
RRC and D1 chassis are the same, the superflex arms that fit the D1 fit the RRC, some members on here have them in their RRC, check out the superflex arms thread in this section. As for the GQ superflex arms, I haven't looked into that as I don't have the money to even think about that.
I'm figuring that if I have to pull a complete axle housing out, then I may as well overhaul them completely (that is my intention anyway) so naturally the bits that attach to the axle will also come under scrutiny.
That is what I am doing in my D1, I have an air locker for the front and a detroit locker for the 80series in the rear and both will have all new bearings and seals when the lockers get fitted.
The main issue is to examine whether or not it is worthwhile spending the additional $ upfront, or to delay wait until before the next big trip north.
It's one thing to do the diffs, but since the suspension needs modification to fit 33-35" tyres, then I have to look at the whole cost. So the ashcroft/maxidrive axles/hubs/cv's are a sound idea. Not sure if I can source ATB centres for an 80 series or GQ, and my guess is they would probably be more expensive. However, the GQ front axle housing is pretty damn strong, which is an added bonus. BUT, I think maxidrive/ashcroft axles etc would be a bit stronger than OE nissan / tojo.
If you don't wnat lockers just limited slip diffs, you can reshimm the 80 series, I had this done to my 75 series troopy (same diff centre) and the GQ diff can be fitted with an MQ/K rear limited diff centre.
For lift, I have gone with the LRA body lift and a 2" spring lift and cut guards and flares so the 35" tyres will fit.
I did this on a price only basis, as the jap diffs where cheaper than the ashcroft set up, but I do lose a little ground clearance due to the larger diff pumpkin on both diffs.
As for strength, I have had a 75 series troopy for 16yrs and have not broken a CV or axle and mine has the smaller (hilux type) diff, so I don't think I will break a GQ one.
