Too late mate.... Its not going to be part of this round... It will cause problems with the TR/DSC
Gday All,
I have 5 tyres, 4 are 80% tread, 1 is 100%, prefer not to leave the spare at 100% so where would you put the one with 100%.
I normally rotate my tyres so this doesn't happen but these are rims and tyres I purchased 2nd hand. Am thinking either rear but just thought I would post the question to others.
Cheers Ean
The rolling diameter of a radial tyre is almost completely independent of the tread depth, it is a function of the length of the steel belt layer. If the system were that sensitive it would freak out every time you turned a corner. I wouldn't worry about it, back left is as good as any place.
Could you buy a 6th tyre at 100% and rotate the 2 100% tyres in on the same axle.
So for instance have the 2 new ones on the front, and 2 @ 80% on the back and 2 @ 80% as spares.
It's basically what I'm doing with 6 tyres and rotating every 10000km.
And no problems with TR OR DSC.
Ron
2013 D4 SDV6 SE
5 wheel rotation normally introduces the new tyre at the back right:
http://www.bridgestone.com.au/tyres/.../rotation.aspx
Corners don't upset the system because it uses steering angle input in its algorithms.
And yes, I've known them to get upset... Even slightly off and you can feel the vehicle "correcting" for it..
It's not a huge difference required to begin to make the machine start to compensate.
You could give it a go... In which case, RHR
Front is the best with AWD vehicles Ean, that's what I was told and what I've been doing as well, on the D2 and now the D4, but I guess rear should be fine also, according to Bridgestone.
The reasoning behind going to the front, had something to do with less drive from the front diff with the 60/40 split, I think you would only worry if the DSC was going off on a regular basis after fitting the newer tyre.
Baz.
Cheers Baz.
2011 Discovery 4 SE 2.7L
2007 BMW R1200GS
1979 BMW R80/7
1994 Yamaha XT225 Serow
Ahh well just as I expected , back left, back right, front , and leave it as spare, or buy another tyre.
eani, meanie, miney , close my eyes and see where it goes.
Thanks all for the replies.
Cheers Ean
Speak to Basil135
He recently asked for the spare to go into rotation and the service manager was adamant its was too late...
