Results 1 to 10 of 26
Thread: Inverter/ Charger Question
    May 2009
    Tatura, Vic
    I have a cheap 150 watt invertor which has a crook fan so I am looking for a new one. Now one of my uses will be for charging/running laptop.
    A friend of mine has used the 150 watt to run his laptop without any trouble.
    However I decided to check the specs on mine and for input it says,
    "100-220 volts ac 1.5 A"
    My question is. If this is using 1.5 amps this would mean that it would be using 360 watts.
    I can't believe that this small charger would be using this much power and if it was I would need at least a 400 watt inverter.
    Am I missing something here?
    Dave.
    I was asked " Is it ignorance or apathy?" I replied "I don't know and I don't care."
    1983 RR gone (wish I kept it)
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
    Crafers West South Australia
    Switch mode power supplies like that with a wide range of input voltages will list the maximum current at the lowest voltage needed to create the output power. So at 220V in it would need less than 1/2 the maximum current specified, ie around 0.5 amps.
    Aug 2010
    Sunbury, VIC
    Dave, I would recommend a 300 watt unit for charging a laptop. If you have a need to use it for anything else, then go bigger again. I just bought a Kogan 1000 watt pure sine wave inverter for $129. Works great, but not sure what life expectancy I'll get from it yet...
    Apr 2010
    South East Queensland near the sea...
    As Bacicat as said, I'd be going for at least a 300W inverter - if that suits your particular laptops power needs.
    A lot of inverters are listed has having "X" amount of watts, however that may well be the max surge current of the unit - you really don't want to be running it at a max surge current, what you are looking for is the continuous current.
    To be on the safe side I would be looking for an inverter with a continuous current of 25% more that what you require to be on the safe side.
    TRS Chip ,D2a I/c, Silcone Hoses, EMS2, 2" Lift, BFG KM2s, QT Diff Guards, 4X4 DE Guard, Shadow Bar. VRS Winch, LR Light Guards, .50 CDL, Provent 200, Slickrock Disconnects, Rovadrive Sump, G4 Roof Rails, D2a SLABS ECU, APT Sliders.DBA Rotors. ABS Ext.
    May 2009
    Tatura, Vic
    I am looking at a 300 watt with a 600 surge capacity. I had no doubt that 300 would do but I just did not understand how my small charger could be pulling 360 watts.
    Bee utey has answered that for me.
    I am looking at one of these.
    SureSine ? Morningstar Corporation
    I am waiting for a nephew living in the US to get back to me on postage.
    Dave.
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
    Aug 2010
    Sunbury, VIC
    That looks like a nice unit Dave.
    Quote Originally Posted by bacicat View Post
    But it's 110V output, so useless for anything other than some switchmode equipment.
    Some gear is very sensitive to modified sinewave so look for a pure sinewave.
    For running a laptop, id suggest going the more efficient Dc-Dc converter route...
    May 2009
    Tatura, Vic
    Go back and have another look. It is available in both Au and US voltages.
    Dave.
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
    May 2009
    Tatura, Vic
    It is a bit pricy but I think it is worth it. It has no fan so has the lowest no load consumption that I have seen.
    The main feature I like is that when the load falls below 8 watts it goes to sleep and draws little current.
    When camped up the river in my caravan I can have it plugged in indefinitely.
    Dave.
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
