Results 1 to 10 of 11
Thread: Wiper motor 1962 SIIA
    Jan 2014
    Googong
    Hi all
    The wiper motor in Betty, my 1962 SWB SIIA, is playing up. Although old I think it is not original. So I'm looking for a new one. I'd prefer NOS but I guess they are as rare as rocking horse droppings.
    Has anyone any suggestions on the source of a new original (or original looking) wiper motor for a 1962 SIIA? All suggestions gratefully received.
    Nic
    How about checking the wiper motor and the drive to the wipers, it might just be a lack of lubrication in the cable or partially siezed wiper shafts.
    The wiper motor itself isn't too hard to sort out either.
    Try running the motor with the wiper cable disconnected to start with
    Safe Travels
    harry
    Jan 2014
    Googong
    Harry
    I should have mentioned that I don't have the later wipers with cable drive - mine is an early single unit.
    Nic
    australia
    Quote Originally Posted by newby@54 View Post
    Hi all
    Nic
    i have wiper motor here jim
    Russell Rovers
    Series I Parts Specialists
    russellrovers AT gmail.com
    Phone 0428732001
    numpty's Avatar
    numpty is offline TopicToaster Silver Subscriber
    Nundle
    They're easy enough to pull apart, clean and reassemble.
    Numpty
    REMLR No 143
    JDNSW's Avatar
    As Numpty says, they are usually easy to fix, with problems mostly due to grease gone hard or dirty connections. Quite rare for anything else to be a problem.
    Jul 2012
    Grease recommendatons
    Hello from Brisbane.
    I also have a couple of small electric motors - heater fan and wiper - on my Series 3 that I was thinking to dismantle and clean up.
    Is there any particular type of grease that is best used for these applications? Ditto the wiper boxes and cabling on the cable drive?
    Jan 2014
    Googong
    Thanks for the responses
    Overnight I remembered that I had a dirty spare wiper motor in a box in the shed. So I dismantled that first in case there were any tiny little springs etc that might come flying out and getting completely lost in my workshop. But as Numpty and John said they are easy to dismantle.
    I then dismantled the one on my SIIA and swapped over a few little things from the dirty one, cleaned it up and lightly sanded the on/off contact and it now works a treat. Amazing.
    But I still don't know if what I have is original to my car. It is certainly a Lucas and the following numbers appear on the back
    CWI 12V G109
    2 55 751978.
    I've attached a photo. Can anyone confirm that this is original to a Sydney built 1962 SWB SIIA.
    Nic
    JDNSW's Avatar
    It is not the motor I would have expected - but the motors were probably part of local content, which may have varied from batch to batch, and I have certainly seen that motor on them back when the vehicles were fairly new.
    australia
    CWI 12V G109
    2 55 751978.
    Nic
    hi tthat type is from a 1955 series one jim
    Russell Rovers
    Phone 0428732001
