Results 1 to 8 of 8
Thread: Mercedes Zetros
    Jul 2011
    Yarrawonga, Vic
    Mercedes Zetros
    Now available in Australia
    I guess its like a development of the 4x4 1418 , looks tough , available in Super Singles or duals, 4x4 or 6x6
    Oz debut for Mercedes-Benz Zetros - motoring.com.au
    biggest, baddest Benz | special-order Mercedes-Benz Zetros 6x6
    Jun 2014
    Holy Moses... now THAT is flex!
    Sent from my GT-I9305T using AULRO mobile app
    Dec 2009
    Williamstown, Barossa, SA
    And it's sat on the hub reduction axles I'm set on having under my truck!! Solid buggers!
    1995 Mercedes 1222A 4x4
    1969 (Now know! Thanks Diana!!) Ser 2 Tdi SWB
    1991 VW Citi Golf Cti (soon to be Tdi)
    'When there's smoke, there's plenty of poke!!'
    'The more the smoke, the more the poke!!'
    Jul 2011
    Yarrawonga, Vic
    whats that compact diff configuration. worm drive like a Puegot ??
    Dec 2009
    Nah, std diff setup, with ring and pinion, but being smaller its all a lot thicker and turning a lot faster than most trucks.. More speed, les torque. The hubs (big cast caps in the center of the wheels) contain the reduction units.. Here is where the torque comes in!
    Dec 2009
    Here's the same axle under a 1997 Mercedes 1831AK. Good ground clearance, and the axles are also good for 500hp. Only downfall is they weigh heavier than std axles which hampered Mercs weight limits in Europe. That's why you also see a lot of the earlier Merc 2435 Prime Movers over here still running on Alloy Rims.
    Adelaide Hills - SA
    What's a ballpark figure for a new Zetros in 4x4 in Aust?
    More or less than a Unimog?
    Jul 2011
    Yarrawonga, Vic
    Top Gear quoted 80,000GBP , which is about half the price of a Unimog, but I guess the configuration will vary the amount vastly.
    Top Gear drives the Mercedes Zetros - BBC Top Gear
