Results 1 to 10 of 14
Thread: LR3 stuck in park
    jbarwise Guest
    LR3 stuck in park
    Hi all,
    My 2006 Disco3 is stuck in park. The gear selector button is broken. I have tried using the small lever (underneath the fascia,) behind the "D" which should override the the switch and at least allow me to get her to the shop to be inspected. This isn't not working. I have also tried pulling the lever and button assembly off so I can try this too. No good either. The initial problem was I tried to twist the lever and button off... Is it possible I have done more damage this not allowing removal or the lever underneath to override the switch.... Please help!!!!
    Jun 2007
    Margaret River
    From what you say it sound like mechanical damage, but,
    Can you hear the brake interlock solenoid click off in the console when you depress the brake pedal? If not, the gear shift lockout solenoid/circuit may be faulty, check fuses.
    jbarwise Guest
    LR 3 stuck in park
    Hi Grappler,
    I can feel the brake lock out operate when the brake is depressed. This is also the lever I am trying to activate from underneath.....
    [ame]https://m.youtube.com/watch?v=UWe1VsRqAeE[/ame]
    I should be able to do this but I cannot remove the lever.
    [ame]https://m.youtube.com/watch?v=9vmzBB8BjcI[/ame]
    This one explains the lever....
    It was all good until I tried to twist it off.... Except for the button being broken. Damned if I know how I am going to get this to a landy specialist now...
    Jun 2007
    Margaret River
    Hmm, tricky
    Are you stuck on the road?
    You will need to at least find neutral in gb or transfer. Im pretty sure dragging it up a flat bed in park would not be recommended.
    With some luck you will jag the release on the damaged selector and get moving
    If the vehicle is safe relax and get some advise tomorrow on getting mobile or what preparation is needed for trnasport
    jbarwise Guest
    Yeh mate, I am at home. Getting frustrated with her now anyway.... Cheers for your help!! I'll tackle her again tomorrow.
    Jun 2007
    Margaret River
    If all else fails, and you need to transport, find a flatbed operator that uses wheel dollies or skids, and is familiar with transporting locked up constant drive vehicles
    Good luck
    jbarwise Guest
    LR3 stuck in park
    So I managed to remove the gear knob and gained access to the selector assembly.... Which is broken (and I bet expensive,) now to disconnect the cable. Anyone able to supply information on how to do this??
    Do I disconnect form the gearbox or does it somehow come apart from the selector assembly?
    Jul 2016
    Skye, VIC
    Quote Originally Posted by jbarwise View Post
    A bit of digging up the past but, I've done the same thing. I went to remove the knob by unscrewing, turns out id doesn't unscrew.
    Now the button is jammed. When I remove the knob the white bit stays behind in the shaft from the gearbox.
    The switch undernearh works and is activated by the brake pedal, but it won't move from park with the switch underneath in either position.
    How did you end up resolving your problem?
    Salty.
    Jul 2016
    Skye, VIC
    So the white bit is jammed won't move either way.
    Salty.
    St Helena,Melbourne
    4.28 MB
    The knob pulls straight up with the white bit attached so I would see if you can remove it from the shifter then re attach the 2.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
