How would it go using the exhaust, which should push far more air into it than a compressor?
could be worth a run?
Bought myself a new exhaust Jack for $85 on-line last week.
Tried it out today using my compressor to inflate it.
Works very well indeed. I took it as far as lifting one wheel. That was enough for the trial.
If using it on the exhaust you need to block off the opposite side tail pipe, some thing like one of those expanding plugs a plumber uses.Standing the bag on its end will give a bit more lift,bit wobbly though!
I've got to get something to block the other exhaust pipe. I understand from this forum elsewhere that these 50mm expanding plugs do the job.
They work reasonably well on flat ground and sand, but they are useless in wet or muddy conditions, the bag just pops out from under the car as it is inflated and on really rocky ground, can puncture, on uneven ground, they tend to roll.
I sold mine, bloody car nearly fell on me a few times, that was enough for me.
Baz.
Cheers Baz.
2011 Discovery 4 SE 2.7L
2007 BMW R1200GS
1979 BMW R80/7
1994 Yamaha XT225 Serow
Found these to be more universal in the bush than other jack systems , ok for most situation along with a jack stand and bbq plate.
Two bottle jacks most of the time when away, if the daughter is with us, we use her Trolley jack, it's the best jack for any job I reckon, I'll borrow it if it is just me and the missus.
At home, trolley jack all the time.
Have also ditched our HiLift as well, dangerous bloody things they are
Baz.
Cheers Baz.
2007 BMW R1200GS
1979 BMW R80/7
Yes I carry two bottle jacks too. I got hung up recently where the track dropped away and it turned out I was stuck on a buried tree trunk. No way of getting the bottle jacks under the chassis where I was hitting (too low) and the front of the car was too high off the ground. The big exhaust jack would have been just the ticket under the front of the car at that time.
Yes they would be good for that situation, and other similar situations, I use the winch for that sort of thing now, but yes I agree, if you haven't got a winch, the airjack would be a good thing to carry, I wouldn't use it to change a tyre or work under the car though.
Baz.
Cheers Baz.
2007 BMW R1200GS
1979 BMW R80/7
