Not sure what's happened, but my interior lamps are not turning on when unlocking, so also not fading when door closes.
They do work when switched to the 'on" position, but on "door" mode...nothing.
They were working perfectly?
Fuse? or some setting somewhere that needs re-setting?
All fixed...
simple requirement to turn the ignition to pos 2.
Seems the time out was initiated today...door left open too long, which switched the system to off, and it seems that closing the doors and locking is not enough to reset the lamps.
All good though sorry for the very simple post.
Hope it helps some others caught in the same trap though.![]()
Yes I have been caught out to when I first got me D2. If you don,t lock the doors the lights time out. As you have already found out turning the ignition on resets it.
Cheers, David.
My Land Rover has made me a better Mechanic........
D2 TD5 Manual, CDL, Detroit Rear, Truetac Front, 2" OME lift, 32" MT Tyres, ARB Bull Bar, Winch, TJM Roof Rack, Driving Lights, Dual Batteries, ARB Side Steps, Rear Draws, Uhf.
