Thread: Tie down & Helicopter point
    Apr 2014
    Australia
    Can the tie down and helicopter points be used as recovery points on the Perentie?
    Feb 2012
    Canberra/Melbourne
    I can't see why not. We suspend the whole vehicle from them under a helicopter. We do use clevises or shackles to attach the strops.
    [SIGPIC]
    2012 LR Defender 90 (BERT) Gone
    2012 Husqvarna WR 300
    2014 FPV F6 Gone
    2005 D3 SE V8
    2011 D4 V8
    2016 Moto Guzzi California Audace.
    Nov 2012
    Acacia Ridge, QLD
    Wink snatch points
    I agree with Carl, but still, I would have a look at them and the way they are mounted onto the front of the car. Remove and check the bolts are ok and high tensile etc.
    From my casual observation the the lifting points look strong, and knowing the army they are very strong. But lifting is a bit different from snatching as you know.
    The landy has some "hardpoints" in the front of the fame where a tube is welded into the frame so a mounting bolt can t crush the frame, just need to do a good visual inspection, "better to be safe etc". cheers simmo,
    simmo
    95 300Tdi Defender wagon
    Nov 2013
    take a look at this thread
    Recovery points on Perentie
    No, refer to the thread in the previous post.
