Results 1 to 10 of 15
Thread: fluid flow through two pipes
    May 2003
    On The Road
    This is not a car question,, more a question on how fluids flow through pipes.
    I recently had to add T pieces to the inlet and outlet of the heater in my D2, this was to run much hotter water through the LPG regulator.
    My question is,
    how does the new T'd hose know which way to flow(though I dont think direction matters)
    and
    what happens to the volume/pressure of water from a 5/8 hose if an identical hose is run off it?
    and this might be the same question in reverse
    how does fluid from a 5/8 hose get back into a 5/8 hose already flowing/full?
    Please get as technical as you like, but words of only a couple of syllables,, ok?
    Crafers West South Australia
    Simple really. Viscosity and velocity in a flowing fluid cause pressure differences between different points of the circuit therefore flow happens in that circuit. If water had no viscosity you would have perpetual motion. In the case of your heater circuit the heater core sets up a pressure difference between the two tees and the extra hoses simply allow more flow from the higher pressure to the lower. As soon as your water pump stops turning all flow stops as there is no longer any water velocity. That is why a loss of fan belt causes converters to ice up in short order and sometimes prevent an engine melt down.
    May 2003
    On The Road
    soooo--
    if the new hose has less pressure, will more water flow through it than the heater?
    soooo--
    I don't think you know what "pressure" means. The new pipes don't "have less pressure", they may or may not have a lower or higher pressure drop at a given flow rate. If you tested the pressure drop* as say 0.2 psi at 2 litres per second through the heater core and its pipes after the tee, and say 0.3 psi at 2 litres a second across the converter and its pipes from the tee, you would say that when connected together (ie the same pressure drop) it's likely that the converter circuit would flow less coolant than the heater. So your pressure drop in a pair of parallel circuits depends on the length of the hoses, the size of the passages in the converter or heater and any other obstruction in the hoses.
    Practically, if your converter hose circuit is 6 inches long expect more coolant to flow through the converter, if it's 6 feet long expect the heater to get more. And as I mentioned a few posts ago, I once converted a P38 and had to add a restrictor to the converter circuit as it was mounted on the drivers side right next to the heater hoses. Yours is on the opposite side and the hoses are considerably longer than those to the heater.
    I just found the picture I posted up way back in 2009
    The converter on that one is just in front of the brake unit and has short hoses.
    * To test pressure drop you could get a calibrated bucket, a garden tap and a pressure gauge at the inlet to the circuit. You'd assume zero pressure at the bucket. Nobody does so in the real world of course, this is just a thought experiment for the kiddies.
    Two Rocks WA
    Hi
    Why not put the convertor hoses in series with the heater hoses?
    reasons for and against?
    My gas convertor is in serires with the heater and I have never had a problem in 20 odd years with 2 Rangies and my daughters disco 1.
    Rangie classic with flapper and omvl convertor
    Brad
    Range Rovers Have Charactors inside them
    LROCWA Ex member 23 years
    1971 Series 2A
    2004 Discovery2a V8 Auto
    2003 Discovery2a TD5 Manual
    1982 4door man (sadly now gone)
    1989 Vogue auto
    2011 TDV8 Vogue
    What would life be without a Rangie?
    May 2003
    On The Road
    I had that brainstorm too Brad
    but the man said it put too much coolant throught the reg,, would leave deposits or something?
    I would, (now!) weigh that up against having 8 more joins in my cooling system!
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by Bradtot View Post
    Hi
    Brad
    This is how i did my 2 rrc's , this makes it less likely to get an airlock and more likely to get a good flow of hot coolant thru the converter.
    Sent from my GT-I9300 using AULRO mobile app
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    theres no simple answer to your question....
    the implied answer is run the 2 heat exhcangers in series. the sequence depends on what you're trying to achieve.
    if your heat echangers add heat to the cooling system then you put them in so the exhanger that adds the lesser amount is first in flow. IF you put it in the other way around then you may find the added heat from the first exhanger heats the coolant up to the point where the second exchanger doesnt get any heat transfer.
    IF your taking heat out I recommend putting the one in the engine bay in last as you'll pick up some heat on the exhcanger from the heat radiating off of the engine.
    if you're doing one addative and one subtractive... take your best guess. I generally route them up whichever way makes the hoses flow better.
    Western Victoria
    The correct place to place the supply "T" to the converter is between the water pump and the heater core regulating valve.
    If you connect the converter and heater core in series, when you (or the climate control) restricts hot water flow to the heater core, hot water flow to the heater converter is also restricted. This is not neccessarily what you want to achieve.
    Williams West Aust
    Quote Originally Posted by Mick_Marsh View Post
    I was under the impression modern climate control units run hot water to the heater core 100% all the time.Blend motors control a flap that allows an amount of heated air to be drawn into the climate controled air if its required.
    Could be wrong,not often
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
