Results 1 to 8 of 8
Thread: Oil leak on axle cap!
    Irymple, Victoria, Australia
    My Perentie is throwing a bit of (differential) oil out from around the plastic cap on the rear axle. The cap is a recent replacement (after market brand). Is there an oil seal further in on the axle that has failed and needs replacing.
    Cheers, Mick.
    1974 S3 88 Holden 186.
    1971 S2A 88
    1972 S3 88 x 2
    1959 S2 88 ARN 111-014
    1959 S2 88 ARN 111-556
    REMLR 88
    1969 BSA Bantam B175
    Hay Point
    Quote Originally Posted by mick88 View Post
    Cheers, Mick.
    No inner seal there Mick. Most likely cause is an imperfection on the inside contact area of the aftermarket cap, some of them are pretty ordinary. It also could be a burr etc on the drive flange contact area. I inspect the cap and flange (make sure it is clean and dry) and then put a bit of silicone around the contact ring when I install them. That seems to stop leaks.
    Cheers......Brian
    1985 110 V8 County
    Thanks Brian,
    Will give it the silicone treatment later today then replace the after market caps with the "real thing" when i get home.
    Cheer, Mick.
    1971 S2A 88
    1972 S3 88 x 2
    REMLR 88
    Jun 2014
    Waitakere, New Zealand
    Would another option be to replace the drive flanges with the HD ones with the threaded cap?
    Mar 2015
    Quote Originally Posted by Bearman View Post
    What silicone would you use for this procedure?
    My appear to be installed this way on both front and rear diffs. I'm assuming this means that they leak without the silicone being there.
    I can't get the plugs out either. I assume I just need a bigger breaker bar for the job.
    Hay Point
    Quote Originally Posted by Chris078 View Post
    Silastic, just a small amount on the contact area. Some will leak for no apparent reason, that's why I use it. Are you referring to to the drain/filler plugs? Make sure you use a socket or the corners will end up rounded.
    Cheers......Brian
    1985 110 V8 County
    Mar 2015
    Thanks.
    Yes the drain/filler plugs. Interestingly, the front diff both drain and fill plugs are just the 1/2 inch input on a socket wrench.
    On the rear, the drain is a 1/2" input and the fill is a 17mm nut.
    I swear I needed a different socket size for just about every nut I removed yesterday changing the engine/trans/PTO/gearbox oil
    Mar 2009
    NSW Mid North Coast
    Thanks.
    Welcome to 60 or nearly 70 years of English automotive engineering excellence.
