Results 1 to 10 of 18
Thread: e10,91,95,98 for d2 v8
    Feb 2015
    gold coast qld
    didn't want to hijack the other refueling post so started this one.
    has anyone worked out what the d2 v8 motor runs best on? just thought i would ask
    i see on the cap it says premium fuel only however my thought is back in the late 90's to early 2000's technology wasn't as refined as it is now so what was 98 octane back then could possibly compare to a good 95 these days..
    i filled the tank up last week with 91 and reset the trip meter to be able to see how far i get on that octane. it is still going to be a while before i finish off the tank as i only travel 2.3km to work and back each day. what i was planning on doing is refueling when the gauge reads the same position as last time i refueled and throw in the same amount of fuel then reset the trip meter again each time and record the results for each octane to see which is the more economical.
    but it will take forever and would like to know if anyone else has worked this out with other d2 owners and averaged the results out to get the answer?
    Nov 2014
    Nirvana near Albany W.A.
    Don't think 98ron was widely available back then but 98is 98 and 95 is 95 Ron , (research octane number) . d2 v8s don't have high enough compression to take advantage of 98 in standard guise
    Regarding measuring differences with gauge.... You wouldn't get even close to accurate
    Sep 2012
    Adelaide Hills
    personally i find i get further on a tank of 98.
    it may cost more, but i feel its worthwhile.
    CaptainJack Guest
    ive done three tankfulls since aquiring my D2 V8 and decided right off the batt to work out if there is any differnce between 95 and 98
    Both tanks have been similar routes - about 180 km a day back and forth to work, combination of a little city traffic and mostly highway diriving.
    First tank was 95 ron and avg 16.3l/100
    Second refill was on 98 ron, and came in at 16.2L/100
    On my second refill i put 87 litres in - so not much 95 left in the tank to water the 98 down.
    taking what could be traffic variables into account, i dont think theres any economy benefit to runnig 98
    Avoca Beach
    There is no way you will see an economy benefit % which exceeds the price difference % in a Low compression RV8 even with Motronic as it will be tuned to run on 91.
    If you are lucky enough to have one of the last D2As with a High compression v8, you may see a benefit as the timing will be optimized for 98 and using 95 will knock back the advance, but it is doubtful that the % increase in economy will exceed the % difference in price.
    An extremely dirty carboned up V8 will see a better increase, but probably an Italian tune up will do the same thing.
    Regards Philip A
    Sep 2012
    Adelaide Hills
    actually my D2 (not D2A), is a high compression v8.
    Nov 2014
    High compression v8 in d2 is relative, cars that can use the 98ron are usually running 11.5 or higher compression ratio, the knock sensors (piezo electric microphones)on d2 won't tell the ecu to advance the timing any further from 95ron to 98ron therefore any benefit is less than negligible, but if your happy paying the extra for the placebo effect then you won't do any damage
    Sep 2012
    Adelaide Hills
    that would be true if timing advance was the only thing 98 was good for.
    Quote Originally Posted by Eevo View Post
    It is a scary day when I find myself in total agreement with you Eevo
    Feb 2015
    gold coast qld
    Is there any way I can check if I have a high or low compression v8?
