Results 1 to 10 of 32
Thread: horn going off when lock car
    Feb 2015
    gold coast qld
    hey guys
    is my horn supposed to go beep when i lock the car after having the bonnet open?
    or is there something wrong with my alarm?
    Alarm beeps because bonnet is not shut properly, or a least the limit switch which tells the alarm the bonnet is closed is faulty.
    2024 RRS on the road
    2011 D4 3.0 in the drive way
    1999 D2 V8, in heaven
    1984 RRC, in hell
    Feb 2015
    gold coast qld
    Quote Originally Posted by Ferret View Post
    oh ok so if the switch is faulty how is it knowing the bonnet was opened in the first place?
    May 2003
    On The Road
    also beeps when a door is open
    Jul 2014
    PERTH, WA
    Quote Originally Posted by mate View Post
    hey guys
    Mate,
    The same happens with my D2a, if I lock the car using the remote key fairly soon after closing the bonnet (or if any door is not properly closed).
    However, it seems to me that if you wait longer (don't know how long, but say, 15 minutes or more after closing the bonnet) before locking, the alarm does not sound a beep.
    Try it and see what happens for you.
    Andrew
    Brisbane, Queensland
    My L322 does that due faulty bonnet switch bracket. I pulled the plug on the switch. I found the bracket holding the switch had some wear allowing the switch to move a little.
    L322 tdv8 poverty pack - wow
    Track Trailer ARN 200-117
    REMLR # 137
    Jul 2014
    PERTH, WA
    Did you manage to fix it?
    Quote Originally Posted by rar110 View Post
    Hi rar110,
    Did you manage to make any modification to the switch bracket, such that the alarm now does not sound when you close the bonnet and then lock up?
    Cheers, AndrewMilne
    May 2014
    Point Cook, VIC
    Quote Originally Posted by AndrewMilne View Post
    Mate,
    Andrew
    After you close the bonnet, open and close a door and you may also find the horn then does not beep when you lock the doors.
    Jul 2014
    PERTH, WA
    Quote Originally Posted by DiscoDB View Post
    DiscoDB: I'LL definitely try that idea!
    Andrew
    Hi rar110, Did you manage to make any modification to the switch bracket, such that the alarm now does not sound when you close the bonnet and then lock up? Cheers, AndrewMilne
    Not yet. The plan is to cut some thin alloy sheet the same shape as the top of the bracket and sicaflex that to the bracket. The model after mine has a steel bracket so it must have been identified as a weakness.
    REMLR # 137
