Ideally you need a 10 x 5 or could get away with an 8 x 5 if it has front opening gate as well as the rear tailgate open.
The problem is that the front spring mounts usually hit the front loading board, meaning that the rear wheel will be off the back deck of an 8' trailer. Having the tailgate up causes similar problems to a fixed loading board, although you could have sleepers or something under the wheels to lift the springs above the tailgate. An 86" with one closed end on a trailer needs at least 8' 3" of deck.
Remember that you need at the entire footprint of both tyres to be on the deck of the trailer and that will probably still mean that the trailer is tail heavy.
You could always remove the numberplate and wire it onto the trailer for the trip!
