Results 1 to 10 of 27
Thread: D3, Towing, and Cape York
    Mar 2012
    Brisbne
    So I have foolishly last minute agreed to follow one of my long time friends up Cape York in July this year, He is taking his Prado 150, as is his Father who is also going in a a Prado 150, and his future brother inlaw in a rusted out Hilux.
    They have all be preparing for over a year now, with TJM winch bars, Winches, side rails, Kaymar rear bars and so forth, they have there roof top tents, and his Parents renting a TVan for the trip.
    Then there is Me. . . 24 years old with a D3 S TDV6 slightly lifted on King heavy duty springs and slightly larger Tires with a bullbar and a Winch that has no brake. .
    My camper trailer is far from finished, and currently has an Axle with Series 3 hubs on it from when I owned a defender.
    So I have a lot of work to get done in the next 10 or so weeks.
    where to start!?
    Im thinking a RAI is probably the first cab off the rank to buy? but after that I would like to think my D3 is ready to go, obviously some storage system would make life easier but is no essential.
    next big issue is, the Prado's carry 150L of diesel, I have 70L(stock tank). . . . Is a long range tank worth it? what kind of money is one going to cost me fitted? then if I get a long range tank, where to mount the spare? rear bars are expensive, mount it on the trailer?
    which points me to the trailer, now it has a hard shell roof top tent ontop of it (alloy shell kind) which is not yet 'bolted down' so that's probably the first thing to do. but that's not the issue or question. its got defender bolt pattern so that needs to change, then once thats changed I need new wheels, what wheels do I get that are cheap, availible and will fit both the D3 and the trailer?
    What is a D3 like towing offroad? Ive towed heaps with it onroad, but ever offroad. And will I be fine towing a trailer up the cape with a more or less stock D3?
    The trailer fully loaded is only 500kgs
    what have I got myself into!?
    Avoca Beach
    There are plenty of fuel stops on Cape York but the further North you go the more you pay. But you would never save enough by fitting a long range tank to justify it.
    I did it in my 91 RRC with my Camp'o'matic (1000kg loaded) a few years ago. I did not do the Southern part of the OTT as Palm creek was a major obstacle then, and a bloke on this forum in a D3 who I met at the creek also decided not to, as it was full of timber and the climb out very wet.
    On the Northern OTT we got as far as the unnamed swamp before Nolans Brook and I turned back as it was up to my crutch for about 100 metres.
    I only needed winching once which was the drop in/climb out to New? creek on the South side.
    A D3 will do everything easily. The determining factor is how chopped up the entries exits are for places like Palm Creek. If you are in a group and have winches , as long as you are prepared to get very dirty and spend several hours winching and cursing and maybe get damage on and underneath you car from logs and crap that people stuff in the holes, go for it.
    The day before I chickened at unnamed swamp , 8x200 cruisers were sunk on a tagalong in Nolans Brook If you are willing to potentially write off your car then go for it. Me , I would rather drive home.
    Regards Philip A
    Mar 2012
    Brisbne
    Thanks Phil,
    I have no intention of damaging my vehicle! if it looks like that will happen ill be turning around and finding another way, (or parking my car up and getting in with one of my mates who is dumb enough to do it and return to my car later)
    I'm thinking for the price of a Long range tank I can get a few Jerry cans bolted to my trailer. . .
    Ellendale Tasmania.
    Snorkle is a good idea, essential for all the crossings and dust you'll encounter, but a car bra will be fine also for the water crossings, you have a camper so rear storage is probably not that important, fuel is 85 usable litres not 70, throw a couple of jerries of diesel on the camper if you can, a good set of light truck AT tyres, a full service, and you'll be fine.
    Air compressor, recovery gear are good additions and a good array of things like cable ties and so on.
    Baz.
    Cheers Baz.
    2007 BMW R1200GS
    Jan 2015
    Milton, Qld
    I did the Cape last year in a Jeep Wrangler petrol, took two Jerrys and didn't need either of them, there is fuel everywhere and if you plan your side trips well you'll be fine.
    Snorkel a must, you wouldn't also go a RTT? It could be pretty wet still in July and pulling a trailer through deep mud/water is a nightmare worth avoiding.
    Mar 2012
    Brisbne
    Quote Originally Posted by Kieren View Post
    my roof tent is a bit big to actually go on the roof. . . and this is why I ask these questions, if Im better off fitting it to my roof (even though its big and heavy and will cause enormous amounts of drag) then ill look into it, I always thought towing a small trailer was better than loading your car right up?
    Nov 2012
    Acacia Ridge, QLD
    Smile winch
    Hi Leroy,
    you have the winch, A winch without the brake working is hazard, I'd fix that, it sounds like it will come in handy.
    What sort of winch is it a warn low mount? I have the brake assembly instructions if it is. They're fairly straight forward to over haul and the parts are reasonable cost and available mail order.
    Storage system in the back would make a big difference, I sold the steel slide out draws and made my own out of plywood. I was surprised, I think the steel storage system in the back weighed more than 80 kgs. Also get the tie down points sorted out, there's aircraft style tie down tracks and ring connectors available at the ARB shop for reasonable cost.
    Good advice was given on another thread "if in doubt chicken out" good luck
    simmo
    95 300Tdi Defender wagon
    Mar 2012
    Brisbne
    the winch is a bitsa, the issue is the gearbox Im using (2 speed) is designed to have a motor with brake, and the motor I am using is designed to have a gearbox with a brake. . .
    its a Tigerz11 gearbox, and a ridge ryder motor from a 12000lb super cheap auto winch.
    not sure if I can retro fit a brake?
    Mornington Peninsula, Victoria
    Swag & a couple of jerrys ?
    Mar 2012
    Brisbne
    Quote Originally Posted by gofish View Post
    Ive been using a swag for 6 months now and am thoroughly sick of it, jsut like I got sick of nylon tents, hence the new purchased alloy hardshell camper box thingy.
    but looks like Jerry cans will be the go for fuel storage
    Leroy
