Results 1 to 2 of 2
Thread: Electric fan for the TD5.
    Dec 2012
    Perth, WA
    I thought this might be interesting.
    Revotec Electronic Fan Conversion Kit - TD5
    From previous experience. Electric fans just don't have the power to pump enough air to cool a motor that was previously cooled with an engine driven fan.
    Also from previous experience. Electric fans do free up a heap (very noticeable) of engine power. You can also override the thermo switch and turn on the fan before the start of a hill so you can make sure the radiator is full of cool water for when the thermostat opens as the engine heats up on the hill. Also as the power initially comes from the battery then alternator then has time to charge the battery in the down hill side.
    Plenty of reasons to have an electric fan but I just don't know if it would have the flow to cool the TD5.
    Happy Days
    Jul 2014
    west of Transylvania
    I've tried one, it was Kenlowe but went back to viscous after short time cos when there were above 30*C outside it didnt have the guts to cool enough, the coolant temp went above 110*C with it as the other(aircon) fan kicked in to help but it still wasn't enough...maybe it works in colder climates like UK but not where it's warm
