Results 1 to 10 of 13
Thread: unsettling bang
    Travelling (NFA)
    Unhappy unsettling bang
    Heard 2 loud bangs from somewhere underneath the disco td5 yesterday whilst reversing in low range.
    Pulled in to a caravan park and engaged low range to make positioning the van easier. Prior to parking i drove about 200m in low range which included a couple of sharp left and right turns and finally reversed onto the site and as I was doing this there were 2 solid bangs...sound like a couple of teeth being sheared off somewhere. Diff lock was not engaged.
    I moved forward a couple of metres, disengaging and reengaging low range again and all seemed ok.
    Could this just have been some wind up in the diff that has corrected itself once the tension was released? If so, is this likely to cause any damage?
    Sep 2009
    Lots of possibilities. Did you have the centre diff locked? If so, could be wind up. There's also a problem with the diff spindles wearing in the casing due to traction control use that may have caused the bangs. Drop drive train oils to check might be worthwhile?
    darwin
    Just sounds like wind up.Were you reversing aand turning at the same time.this still puts a strain on something.could of been the tyres deforming etc
    Darwin
    03 disco 2a td5
    93 tdi disco [gone to a better home]
    2003 d2a v8 retired hurt
    1988 k100rs bmw gone
    85 county izuzu [gone to a better home]
    69 series 2a [gone to a better home]
    series 2a [gunnado]
    series 3 [gunnado]
    and the tinny
    NSW SW Slopes
    Associated more with clunks, vibrations and squeaks rather than bangs but worth checking the DC joint on the front tail-shaft.
    St Helena,Melbourne
    4.28 MB
    No windup if it was unlocked.
    Sent from my GT-I9300 using AULRO mobile app
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    NSW SW Slopes
    Quote Originally Posted by rapserv View Post
    ...there were 2 solid bangs......
    Did you disengage low range before moving forward after the bangs? Perhaps it jumped out of low range after not being fully engaged.
    Travelling (NFA)
    mmmm...diff was not locked :-(
    Travelling (NFA)
    that was my first thought graeme. from memory I think I rolled forward slightly disengaged and then re-engaged low range and all seemed ok then.
    its often tight to engage (normally impossible if not moving slightly) and I make a point of easing the lever fully into position. Having said that, there is a possibility that it may not have been fully engaged. I tend to use LR for manoeuvreing the van slowly into tight places and this is the first time this has happened.
    Travelling (NFA)
    Quote Originally Posted by bsperka View Post
    will drop oils and have a look for any unexpected bits of metal
    Travelling (NFA)
    Quote Originally Posted by lewy View Post
    diff lock was not engaged so wind up unlikely. bangs sounded metalic so I think this rules out the tyres
