Results 1 to 10 of 17
Thread: MAYDAY Can you lock a D2 into 2WD for emergency?
    Feb 2015
    New Zealand
    I noticed today while doing a service the front double cardan shaft on my 2000 TD5 is so shockingly flogged I am very surprised it hasn't exploded!
    My question is can I lock the centre diff using some vice grips or something, remove the shaft and drive her in RWD for a couple of days until I can get the parts to rebuild? I'm in a real jam and need to get to work tomorrow and my wife is gone for the weekend in the spare car! Of course its after hours on Friday and no-one local has the parts in stock!!!
    Bacchus Marsh Vic.
    Yes you can is the good news.
    Remove the tail shaft and lock the centre diff using a 10mm spanner.
    Some folk have driven like this for up to a month.
    Cheers, Kyle
    The Good Oil.
    When did you last visit?
    Nov 2012
    Acacia Ridge, QLD
    Thumbs up 2 wheel drive disco
    I'm not a disco owner, ( it has electronic gadgets i don't understand), but I think youre on the right path. Only recently one of the guys was describing doing a similar thing.
    If your transfer case has a diff lock youre in business. Just remove the front shaft and lock the diff, should not be problem for a few days.
    I'd proceed with the drive shaft removal, and wait advice form the experts , sure to be coming when they get home from work. (or the pub ) good luck
    simmo
    95 300Tdi Defender wagon
    Sep 2012
    Adelaide Hills
    only if you have a CDL
    Feb 2015
    New Zealand
    Quote Originally Posted by alien View Post
    Thanks, is the spigot easy enough to get to from under the car? Mine should have it as it's a 2000 and I think '01-02 were the ones that missed out?
    Jul 2014
    west of Transylvania
    You can get to the spigot if you crawl under and reach up to the top of the trasfer box's front RH side, some handiness is required but not a killer, i was in the same situ long time ago before i fitted a linkage and locked the diff on the side of the road... turn the spigot clockwise, it's travel is not big, about 45 degrees
    Feb 2011
    Hobart, Tasmania, Australia
    I think the correct answer is more accurately maybe...
    There's three different variants and only two will allow it.
    The easiest is the last D2a models which have the diff lock shifter as part of the high/low.
    There's some models which have the diff lock mechanical parts and will require you crawling underneath to engage it using a spanner - I believe these are the earlier released D2's.
    There's some models which do not have the mechanical parts and therefore you cannot lock the transfer box - I believe these are the models prior to the D2a release.
    This is all assuming that your transfer box has not been replaced or a mechanism installed.
    Good luck. If you don't have a D2a then your 50/50 (without knowing the year) and you can confirm when you stick your head underneath.
    Dec 2012
    PRIMBEE, Wollongong NSW
    this may help
    this foto may help you find the spigot to lock the CDL,,need 10mm open ender
    Put spanner on from rear of car and push out to the Passenger side
    Paul
    Nov 2013
    Cobram
    CDL
    Is that a wiper motor adapted to your CDL lever?
    Feb 2015
    New Zealand
    Thanks all, I've just finished breakfast so will head out to the man cave shortly to have a look see.
