Results 1 to 4 of 4
Thread: S11 soft top similar to s111?
    preston
    I recently bought a s11 workshop from shannons for a uk buyer
    Most generic parts are easily sourced but in the short term I need to get the soft top sorted for the cab
    I need door tops, windscreen canvas bracket, door top canvas brackets and the two hoops for the cab.
    Are these soft top parts similar to the s111 gear because there are lots of s111 ffr's around?
    The parts were removed by a remlr member and I've tried to contact him to purchase back any remaining parts to no avail.
    Any help much appreciated
    David
    australia
    hi have the shark tooth top rail and other parts phone me regards jim
    Russell Rovers
    Series I Parts Specialists
    russellrovers AT gmail.com
    Phone 0428732001
    JDNSW's Avatar
    Series 3 and Series 2/2a soft top parts are either the same or interchangeable. Both will have some special military bits, but most of these will interchange.
    East-South-East Girt-By-Sea
    1.20 MB
    The workshop bows, doorseals and windscreen top are exactly the same as the SIII FFR. In fact the second bow on the workshop transom/bulkhead is the same part as the rear bow on a 109 or 88 SIII, the only unique part is the short connector between the rear bow and bow with the door seals. This can be fabricated using some flat bar or cutting and flattening the end of the connectors on the other hoods.
    Getting the canvas cover may be difficult, but the manufacturers in the UK should be able to make it using parts of their standard templates.
