Any of those 3 will fit (all the same item). pick the one you like. original part no was NRC3907.
Started pulling the dash apart on the weekend after we had a slight cable melt down (more on that in another thread). In the process the back end of the ingition switch dropped off in my hand and then when I put it back together and tried it the spring return on the key broke. So a new whole barrel and switch assembly is needed.
Can anyone confirm the part number for the ignition barrel and steering lock for the 110 85 County? I have looked around and I think the original part was
QRF500110 but this seems to be superseded by LR041320. However other than ebay these are all listed for later model from 90 on.
QRF500110-BM Superceded by LR041320-Land Rover Parts Direct
Ignition Lock & switch Land Rover Defender QRF500110
Land Rover Defender V8 Steering Column Lock Ignition Complete KIT Bearmach | eBay
Cheers......Brian
1985 110 V8 County
thanks Bearman. just have to find time to pull the dash apart and fix the melted wires and replace this while we are going.
