My guess would be a 4" Grinder with ultra thin 1mm cutting disc for the top plunge cut, finish with a hacksaw blade for the vertical cut, and finish with a small file.
 Master
						Subscriber
						Master
						SubscriberHi and happy easter to all. I purchased a Rijidij rear wheel carrier for my MY14 Defender. The fitting requires cutting a slot in the infill strip between the chassis and the door. Not sure how to start this and what tool to use. A call to help, from anyone who has installed said carrier, how and what tools did you use to cut this slot ?.
Thanks in advance for any assistance.
Tony
My 20 TD 240 Defender
Series 3 Ute
-Mitch
'El Burro' 2012 Defender 90.
I drilled some holes smaller than the suggested size. Then put the angle grinder through the middle to make a slot then spent a couple of hours with a file.
I would have been quicker if I'd bought a new file at the start instead of waiting until I'd done most of the job.
I also drilled holes the whole length like so,
and then used a thin file to make it nice and rectangular.
I then coated the bare metal with touch up paint so it wont rust later on.
 Master
						Subscriber
						Master
						SubscriberThanks for the tips guys, off to Bunnings and then hopefully a successful install.
Removing the rear door card without damaging any clips will be interesting.
Tony
Series 3 Ute
I would go and buy something like the following,
SCA Door Trim Remover Set - 5 Piece - Supercheap Auto Australia
It comes in handy when you own a Defender!
Removing the back door trim is quite easy, just take your time to pry off where the clips are located.
Here is a picture of the clip locations,
I went and bought a very thin piece of rubber from Clarks Rubber, to place between the door and new door plate so that it wouldn't scratch the paint if I ever decided to remove the holder in the feature.
Stop by a super cheap auto store and get a trim removal kit. About 20 bucks. I persisted without one for years, but they really are worth using to minimise damage.
-Mitch
Great minds think alike it appears!
-Mitch
 Master
						Subscriber
						Master
						SubscriberJob done I did buy a set of trim remover tools from super cheap worked well.
All back together again and working.I would like to meet the man who can do the job in the recommended 2 hours .
Thanks again for all the tips.
Tony
Series 3 Ute
