Results 1 to 10 of 12
Thread: Direct injection carbon build up
    Jul 2010
    My EGR blank off has arrived & I will be fitting as soon as i can get hold of a gasket that didnt come with the kit. I googled Utube to find a video of how to do it yes there is one. While searching Utube i came across the something i hadnt heard about previously. Direct injection engines have carbon build up issues around the valves & manilfold. This is because no fuel mist is cleaning the back of valves or manifold. Some BMW petrol engines suffer so badly they actualy blast the carbon off using walnut shell as a blast medium. They do this with the engine still assembeld. I also read the egr is supposed to help clean the manifold & valves as the recirulated exhaust gas contains moisture that steam cleans the manifold . May be a good theory but i dont think it works in practice. Has anyone had carbon build up problems with a TD6 or had a good look at the valves with the manifold off .
    Mike
    Brisbane, Queensland
    I read a while back the early NT 2007 Pajeros had carbon build up. The solution was manifold off for a clean.
    Our Peugeot was suspected of having carbon build up as the cause of engine surging. I was charged for some chemical treatment that was suppose to clean the manifold. An EGR blanking plate ended the problem.
    L322 tdv8 poverty pack - wow
    Track Trailer ARN 200-117
    REMLR # 137
    Dec 2011
    Toowoomba
    Sounds like someone on Utube making a good story re "direct injection engines-- not cleaning back of valves etc". All diesels have the diesel injected into the chamber after the valves, whether indirect (chamber) or direct injection.
    EGR blanking-- there shouldn't now be any carbon in the inlet manifold or back of inlet valves!
    Dec 2009
    Tyrendarra Vic (South West Vic )
    You will find a hell of a lot of gunk in the manifold that will need cleaning out. Thick black sticky **** . Comes through from the ERG valve.
    Jul 2010
    Your not wrong
    Quote Originally Posted by 33chinacars View Post
    Just got rid of the ERG valve . Used a blank of ebay. I could not believe the amount of sticky black carcenagenic looking crud in there. I will be pulling the manifold off at next service & giving it a good clean. Only driven 10 ks so far down to Avalon & back but it seems quiter & idling smoother already. Now for a remap & cat back exhaust system.
    Dec 2009
    I'm sure you will be happy & so will your motor
    Manly QLD
    this is an issue that has come up with the new DI petrol engines. Diesels have had DI for decades (300tdi) and I've not come across problems on a DI diesel.
    VW have added a 2nd set of injectors on the mk7 GTI and R. the primary injectors in the cylinder and the 2nd set adding fuel into the manifold to prevent this issue.
    Aug 2010
    Sunbury, VIC
    I've had the head off mine, and the carbon build up was mild, but there. Nothing to get in a twist about and it had 230,000KM on it. EGR blanking was fitted a couple of years ago. Bigger problem as mentioned is the thick black sludge that will be in your inlet manifold from the EGR. It's bloody hard to shift too. I had my manifolds in my mates spin wash for 8 hours solid to loosen it all up, but the were sparkling clean when I reinstalled them.
    I took the opportunity to pop all the valves out anyway and clean them up, as well as the inlet tracks on the head. Engine runs very smooth now, but no idea if that's anything to do with what I've done, but it sure didn't hurt.
    Aug 2010
    Sunbury, VIC
    Quote Originally Posted by Defender Mike View Post
    Then a transmission rebuild...
    Jul 2010
    Glass half empty
    Quote Originally Posted by bacicat View Post
    its going so well with the egr off i dont think i need it.
