Results 1 to 10 of 12
Thread: Where / what wheel spacers for D110
    May 2013
    Manly, NSW > AKL, NZ
    I recently put on bigger (265) tyres onto my Defender 110 300tdi. There is rubbing at full lock and am thinking about putting in some spacers. wanted to check here if anyone had recommendations on which ones ?
    thought about a lift but I doubt that'll rectify the rubbing issue.
    I suppose you don't want to know they aren't legal.
    May 2013
    am in New Zealand - legal here as far as I'm aware.
    Aha! I saw the Manly and the NZ in your location.
    Douglas Park, NSW
    Quote Originally Posted by billnus View Post
    They're not just rubbing on the radius arms? If so, adjusting the lock stops will sort that out.
    Feb 2013
    Sydney, NSW.
    Land Transport Rule - Tyres and Wheels 2001 | NZ Transport Agency
    Requires certification in N.Z.
    2.2(5)(d) and,
    3.1(3).
    Regards,
    Mike.
    Feb 2013
    Sydney, NSW.
    Also,
    1http://www.lvvta.org.nz/documents/standards/LVVTA_STD_Wheels_&_Tyres.pdf
    Bugger, due to issues posting the PDF above, I have added a 1 before the http, delete the 1 then go to the website, not sure what causes it to play up, maybe someone with more internet knowledge than me could fix it so the PDF shows up properly here....?
    Section 2.5.
    This may apply to your vehicle....
    The laws/regulations in N.Z. Are a lot simpler and easier to navigate than the current Australian laws/regulations.
    Interesting to me that they allow mechanical beadlocks on rims.
    Regards,
    Mike.
    Jul 2012
    ferntree gully australia
    I not sure what wheels you are using , I put 265X75 16 ON Disco steel rims and they rubbed the spring hanger at the top , rubbing the inside of the tyre , That was on a 110 County , So I ended up buying 20mm offset rims , That fixed my problem , plus look at front wheel stops . This also kept It legal just inside wheel arches !!.. Jim ..
    Jan 2011
    If you decide to change your rims anything between positive 15 and negative 25 will fix rubbing issues and improve the turning circle.
    Im unsure about which spacers are good as not many in Oz use them but i would want at least 20mm thick ones.
    Michael.
    May 2013
    thanks all - i'll probably just adjust the stops and deal w/ the reduced turning circle. it was really just the first couple days of driving it getting used to the new tyres, not as annoying as I first thought. they're 265/75 muds on boost alloys.
