Results 1 to 10 of 26
Thread: PTO driven air compressor - would it work ?
    Bracken Ridge, Qld
    Just for the sake of discussion.
    What would be involved in using the PTO to drive an air compressor and could it be done at a reasonable price ?
    I stress I am not contemplating actually doing it (my max air does me just fine)
    Unless...... :wink:
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
    Nanny state UK...
    It probably could be done....
    Mind you, if you're not running aircon on a 200/300TDi then you could always use the Aircon compressor mounting (with Aircon compressor if you wanted...).
    Mark.
    Bracken Ridge, Qld
    But I AM runing aircon.
    It's not England here you know :roll:
    It's sunny for a start [img]style_emoticons/<#EMO_DIR#>/tongue.gif[/img]
    (and yes I am reading paul's thread on the air con compressor thingy)
    gone
    1996 Discovery 1
    current
    SYDNEY -in the shire.....
    thats an idea ive been thinking about but havent looked into it yet.
    i want to run a york compressor off the PTO cos it wont fit under the bonnet....
    HSVRangie Guest
    Do it
    Michael.
    nutgrass Guest
    http://www.4wdworld.com.au/products/maxidrive/
    Not sure how up to date this is, but looks like MaxiDrive can gear up there PTO drives to suit.
    Warragul, Victoria
    Driving the Lawnmower at work today I had the same idea and as soon as I got home searched the forum to see if anybody else had the same idea.
    Has anybody actually done it yet?
    LR did this back in the 50s,60s,70s, 80s etc.... I think they were high out put units for construction work. Another option would be to get a compressor from a semi, drive it with a hyd motor and then get the MD hyd pto to run it......if you went this route, you could design the system with a winch in mind and have the whole set up....the MD stuff will drive a pump that will put out 60ltrs/min no worries
    Queensland
    Hey we have been talking air compressors on another thread for ages.
    PTO and engine belt driven.
    Get with it.
    Warragul, Victoria
    Quote Originally Posted by 123rover50 View Post
    Get with it.
    Thanks, a link to the thread and less sarcasm would be nice.
    I only went by the search result that matched my keywords, silly me.
