Results 1 to 3 of 3
Thread: Safe removal airbag compat bull bar
    Greeny Guest
    Hi
    I have an ARB airbag compatible bull bar I need to remove from my Disco TD5 to respray it. It seems easy enough to do and I will remove the battery leads to stop any potential airbag disasters - I hope, but is there anything I need to look out for? :?:
    Greeny
    SYDNEY -in the shire.....
    it should be just 4 bolts holding it on...shouldnt have anything to with setting off your airbags unless you crush the front end sensor.....its not bolted to the bullbar but rather on the chassis rails somewhere.....if you hit hard enough to crush the chassis rails up to the sensor in a collision...then the sensor will go off.
    I would think any electricals would just be for lights?
     2005 Defender 110 
