19th May 2005, 12:57 PM
Mouse urine update - yes the drain was blocked
Hi All
I went in to the cabin air intake today and found a pool of water blocked with the kind of rotting stuff you find in roof gutters.
Cleaned it all out and unblocked the drain. I think this will sort out the smell and also the excessive moisture in the air that comes out which makes the windscreen fog etc.
Looking at the set up for the air intakeI am thinking it is a bit over confident to hope that it has something to do witrh water leaking into the foot wells.
Thanks all, Defenderzook in particular for the advice.
19th May 2005, 06:00 PM
any time buddy...the best thing now is when you try and defrost the windscreen it wont fog up even more as soon as you turn the heater on...it will actually start defrosting......wow...
