My experiences are that you've done the right things but the damage has started and not long down the track it will increasingly fault as components break down.
I'd ensure the ATF cooler is absolutely clear so that it can cool the ATF and I would assume replacing the burnt ATF wouldn't be a bad thing either so that it can work properly.
That said, I would also keep driving it incase you got away with it!
