Results 1 to 10 of 15
Thread: extractors = burnt out starter
    crossy Guest
    is this a common problem?
    holden six with extractors on a series -
    i have just lost another starter motor on the series 111
    second one in a year. I think the problem is the closeness of the extractors to the starter motor. too much heat.
    has any one fitted fibre glass tape or heat shields?
    i think the tape should fix the problem but want to know how well it holds up to mud, water and gunk over time.
    Its not all bad - i'm getting good at kick starting the bastard.
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    header tape on extractors = good, as long as they are steel pipe not stainless steel or some sort of alloy.
    steel will crack with age as they become soft from the slow cooling tempering them. the odd creek can fix that tho [img]style_emoticons/<#EMO_DIR#>/tongue.gif[/img]
    i have header tape on my pipes back past the gearbox and overdrive and it really cuts down the noise and heat from the holden engine.
    also fitted to my disco from the flexable back to the rear of the gearbox, cuts down noise and heat in cabin heaps...
    the 50mm tape on a half-lap wrap works great. a hose clamp at each end to stop it unwrapping and away you go [img]style_emoticons/<#EMO_DIR#>/tongue.gif[/img]
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Cobar, New South Wales
    G'day Crossy, i run header tape on my bike, it uses stainless headers and the tape cuts the heat right down, they get the odd dose of water and gunk and clean up ok, the heat soon drys the tape out again [img]style_emoticons/<#EMO_DIR#>/laugh.gif[/img] + as incisor says it cuts down a fair bit of noise, no sign of it coming apart. Can't say i've ever had much trouble with holden sixes+extractors & the heat burning out the starter? I'd say a cheaper option would be to make up a heat shield and bolt it on via the manifold bolts, or if your engines an early one (EH - HK) there are bosses on the block you can bolt it too in front and above the starter. Hope that helped :roll: [img]style_emoticons/<#EMO_DIR#>/laugh.gif[/img] , i'm interested in how you get on as i'm doing the holden conversion at the moment.
    Bill
    crossy Guest
    thanks guys. i'm sold on the tape solution.
    didnt think of the noise issue. added bonus in a series [img]style_emoticons/<#EMO_DIR#>/smile.gif[/img]
    Jun 2003
    Launceston, Tasmania
    I'm not sure that is what your problem is. I've got extractors on mine, and whilst close to the starter, it hasn't missed a beat yet.
    That said, after I make some changes to my exhaust to accomodate an overdrive, i'll be putting the tape on mine as well.
    1994 Discovery TDi
    2004 Discovery 2 TD5
    2010 Discovery 4 TDV6
    Try the heatshield as well as the tape. The RR has a heatshield that protects the starter and the engine mount, obviously holden had them too. Just fashion a shield out of bent tin, drill a hole in it and bolt it onto something. (better make that 2 holes to reduce reverberation).
    Now if you had a Land Rover motor, you'd have had a starter handle. All these cross-species organ transplants are not good for the health of the breed. :wink:
    Padstow NSW
    wont be the heat!
    if if you need a new starter, the best ones to get are the
    high torque ones, the body is smaller than the old ones
    and it cranks i bit slower. i use them cos you can get the
    starter in and out with out removing the extractors.
    bought one last year brand new for $119.
    Try making up a alloy heat shield. They are rally good at stopping the heat.
     2005 Defender 110 
    rangie5litre Guest
    I now have the tape on my 5L exhaust, the starter is one of those tiny
    índuction' type ones. It was originally wrapped in silvery foil like stuff, was OK until it went crispy and melted to the ign wire that goes to the starter! I took that off and wrapped 3 metres of 'glass tape around the pipe near the starter instead. I'll do the same down both sides of the trans. as well and around the crossover pipe too. It's amazing how much heat is tranferred thru the floor! Good luck! 8) Cheers Scott.
    Brisbane Australia
    In my boy racer days I had lotts of hot red motors with big cams, big heads & 3 carbys all had extractors and never had problems with cooking starters.
