Results 1 to 10 of 11
Thread: 115mm intercooler
    Oct 2006
    canberra
    115mm intercooler
    Anyone fitted one of these Land Rover Discovery 1 300TDI 90 110 TDI PRO Intercooler 90 98 Diesel 115mm Core | eBay
    The original is leaking and needs to be replaced and I'm not made of money so I was looking for a reasionably priced replacement. The factory coolers are well known for leaking around the tubes I have two leaky ones
    St Helena,Melbourne
    1.13 MB
    I think in the D1 section there is a post on fitting one , needed some work to get it in.
    Sent from my GT-I9300 using AULRO mobile app
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Oct 2006
    canberra
    Did some measuring last night looks like a pain in the arse. But still cheaper then the 400 the radiator bloke wants for a new standard one
    NSW far north coast
    Had an interesting chat to one of the blokes at TRS in SA the other day, he reckons the standard IC has a pressure drop upwards of 3psi ?
    Never measured it myself, should stick some gauges on and check, but if so that's pretty ordinary so a thicker core should help.
    Jan 2012
    Melbourne, Victoria
    That is interesting... I tapped a connector into the inlet manifold on my Tdi some time ago and have measured both turbo and manifold pressures and I've never really noticed any major difference in psi between them, I've since found that the ic was leaking as well which would show a bigger pressure drop at the manifold??
    In comparison the new full width Allisport ic I've now fitted is showing around a 3-4psi difference from turbo to manifold..
    Oct 2006
    canberra
    Quote Originally Posted by rick130 View Post
    Where you been hiding rick? I'm just going to put a stock one back in. Not Interested in cutting up the fame ect to fit a chinga cooler in
    NSW far north coast
    Been a hell of a year Matt.
    Tell you about it later.....
    Oct 2006
    canberra
    Sounds like it some of the boys have been wondering . Any how you know where to find us mate
    Mar 2010
    wonga park vic
    re the allisport ic, did it make much difference to the engine? Have you got stock turbo and injector pump?
    cheers ian
    Jan 2012
    Melbourne, Victoria
    Quote Originally Posted by istevo View Post
    cheers ian
    It has definitely made a bit of a difference, it's currently running a Vnt and Turner Engineering head but still on stock tuning so there is definitely room for improvement to fully notice and get the most out of the cooler air and turbo, it also has an underlying issue that I suspect is pump timing, hopefully going to get it properly set and tuned up at the same time.
    The turbo is currently putting out 16-17psi but the engine is only getting 13-14psi due to the larger capacity system so there is an improvement to be had there as well.
    But anyway probably the most noticeable thing I've found with the larger IC is the quicker temp recovery after going up a hill, egts definitely seem to drop faster and I would say the overall temp has been ever so slightly reduced as well.. Haven't driven it extensively but just what I've noticed so far!
