I have 210,000 klms on a 2009 TDV6 and apart from Wheel Bearings and me putting the wrong fuel in, it has been very reliable. I do get it serviced every 12,000 and I tow a 2500kgs van, and I wont be getting rid of it anytime soon!!
It appears so: ... Landrovers all leak, "do heads" and break diffs and transfer cases constantly ......
Caravaners Forum • View topic - How Many KMS is Too Many KMS for a Diesel 4WD
seeya,
Shane L.
Proper cars--
'92 Range Rover 3.8V8 ... 5spd manual
'85 Series II CX2500 GTi Turbo I :burnrubber:
'63 ID19 x 2 :wheelchair:
'72 DS21 ie 5spd pallas
Modern Junk:
'07 Poogoe 407 HDi 6spd manual :zzz:
'11 Poogoe RCZ HDI 6spd manual
ive read on this forum, that if your d3 diesel goes bang, replace it with something else.
Mark
Of all the things I've lost, I miss my mind the most![]()
2003 D2a TD5...gone...
2000 D2 V8...gone...
https://bymark.photography
It's true that the old LR's have left a less than positive feeling in the 4WD general community. A fair bit of that is the build quality of the 1970 ~ 1990's British motor industry, but it is also due to the British vehicles being quite different to the Japanese template used for most of the 4WD's sold in Australia.
The D3 / D4 / Sport are quite different beasts to any previous LR product. There are no common components with any of the older cars, re-designed from the ground up, as are the factory lines that build them. It's no longer true that you can find your way home by following the oil trail.
I would argue that there are less reliability issues with post-2005 LR's than with post 2005 Cruisers. But again, simple issues that are fairly straight-forward to address if you know the vehicle are often quite outside the experience of traditional Japanese-built 4WD owners or service centres.
One needs to educate oneself on a D3 to really get the best out of it. But that's half the fun
Gordon
