Hyundai electrickery troubleshooting
My partner has a 2012 Hyundai i30 a 1.6L diesel, affectionately named 'the dirty 30' (She never washes it). It's a great little car, super efficient and comfortable enough for the runabout it is... but has just developed a problem.
Today I noticed the first issue we've had with it- both low beam headlights are dead.
So this evening I donned a headlamp torch and the multimeter, and did some testing- which proved inconclusive. I'm unsure if this is one of those vehicles with something tricky going on in a circuit(s) that should be pretty simple. Any advice welcome!
Testing shows:
1) 12.34 V at the battery
2) Headlight fuse (both LH and RH Low beam - presumably 2 circuits) are intact.
3) Continuity between battery + and fuse
4) Continuity between fuse and headlight connector
5) Headlight relay clicks when headlight stalk switch is switched from park > Lo beam (not a sticky relay)
6) No voltage present at the headlight connector with the low beams ON (I triple checked- both LH and RH light connectors).
7) I didn't check continuity of the globes due to the lack of working space, but assumption (the mother of all F-ups) makes me think that they are OK.
I should note that both headlights have failed at the same time, leading me to suggest globes are OK.
Given that there is 2 fuses (1 for LHS, 1 for RHS), and presumably 2 circuits I'm guessing this rules out them being wired in series? If wired in series, if 1 globe blows, the other will not work.
Is there any other tests I should do before I approach the dealer to have a Look (vehicle is still in warranty, if it's in fact an electrical fault, not a globe fault)?
Is it possible that Lucas, the lord of darkness has left my Puma, and infiltrated the innocent i30?
-Mitch
'El Burro' 2012 Defender 90.
