A set of Mulgo rails would have seen you right with no other mods required...
Due to a failed right knee op i could not drive my 130 dc,could not even get in passenger side. Got busy last week and modified my seat rails and picked up about 3" more rear travel.First i marked where seat runners hit lip behind seats,cut out a small section so seat could pass.There are two raised lumps on seat runner which i ground off.Next i drilled out two indents on seat runner and pushed seat mounting rails as far to the front as possible.Two ball bearings came out of each rail.The front has same setup so seats go no further forward but can come back.Finally ground off protruding thread from rear seat mounting bolt between seat runner and mounting rail or it hits on rail mounting bolt.Only down side is now squab pins no longer go in holes or seat will not go back so pins sit on top of rail and still clip into place at front.Bit primitive but works.Can now drive and sit in passenger side,but only just.
