Results 1 to 9 of 9
Thread: Nugget's Defender Front Light Guards
    Jun 2010
    Flat bar style Defender light guards the same as seen on Nugget's 130. Supplied with Stainless Steel nuts and bolts as well as an aluminium re-inforcing bar to spread the load bearing of the bottom fixings.
    More pictures and fitting description can bee seen in my 130 build thread..
    nugget's Defender 130 build
    $185/set delivered from Nugget . Also available from Mulgo.
    DiscoMick Guest
    They look good.
    Sent from my GT-P5210 using AULRO mobile app
    Dec 2012
    Melbourne, Victoria, Australia
    I need more disposable cash, i want one of everything you make for a defender!
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    wish i had a defender again so i could put some of it on!
    nice work big fella!
    is time you bought an old rangie....
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Nugget Gear will also be available "down South" from British Car Components (BCC) in North Melbourne very soon.
    We intend to fit some of it (like these most excellent light guards) up to our first project car "The Count" in the coming months. As such, a good chunk of it should be available for local viewing and "touchy feely" fairly soon.
    Forget "banging away" on the computer, just call (or call in) and let us know if you want anything specific "in stock" to help with your decision making prior to purchase.
    Hoo-Roo,
    Dave.
    Jun 2010
    Just a bit more info on the front light guards as mine are, in my humble opinion, a bit neater than others on the market
    The top securing points can not be accessed from the inside so Rivnuts are the best option. I have used 5mm Aluminum ones to be compatible with the ally panel. I was never happy with the fixing on the 110 as the top bar sat on the head of the rivnut which had it sitting proud of the panel. I have machined a recess in the back of the top bar to accommodate the rivnut head which means the top rail sits flush on the panel, spreading the load more effectively.
    Fitting is dead easy with 2 rivnuts at the top and 2 bolts and flange nuts at the bottom. I also beefed up the bottom securing by using a 20 x5 ally flat bar on the backside of the panel which gives far greater support. All the bolts and washers are stainless of course.
    The top rail sits completely flush with the recessed back to accommodate the head of the rivnut
    And the final result, all frocked up and no where to go J
    Apr 2015
    Wellington NZ
    Talking
    Quote Originally Posted by INVSBL View Post
    Same here too.....
    Quote Originally Posted by nugge t View Post
    I think i shall be ordering a set.......
    Great gear
    Just received my Nugget Stuff light guards order in the mail yesterday.
    Very professionally finished and packed, and right on time.
    These are a very slick piece of kit and anyone bothering to go O/S or Ebay searching for anything better for the money must have rocks in their head!
    Great Price, Great Product and Aussie made!
    Thanks for proving it can be done Nugget!
    Hoo-Roo,
    Dave.
    Oct 2012
    Manila, Philippines
    Question, if you need to remove or replace any of the lights behind this, will you have to undo all 4 securing points to get to them?
