Results 1 to 10 of 15
Thread: Cant get the stereo out!
    Bathurst NSW
    Hi all, i dropped my Disco into the Auto Electrician this morning to have a CD player put in, i just dont have the time or the energy to do it myself. When i went to pick the car up, all excited to listen to my new CD player i was dissapointed to find that he was unable to get it out. Is there a trick to getting it out? Do you need special tools, the removal gear he had didnt work. Matt
    <a href=https://the4wdzone.com.au/wp-content/uploads/logo.png target=_blank>https://the4wdzone.com.au/wp-content/uploads/logo.png</a>
    The 4wd Zone/Opposite Lock Bathurst
    263 Stewart Street, Bathurst, NSW
    http://www.the4wdzone.com.au/
    Discounts for AULRO members, just shoot me a PM before you purchase.
    May 2002
    Sydney, Australia
    There is a special tool - but most car radio shops should carry these, as the one LR used is similar to other manufacturers.
    You can make your own tool - use a metal coat hanger or thick metal welding rods and make them into a U shape - need 2 as one is required on either side at the same time.
    Slide them into the 2 holes either side of the unit - this should release the securing tabs and you should be able to pull the unit out from the tape deck.
    HTH
    LRH
    Disco 4 SDV6 Auto
    Disco 4 SDV8 Dual Cab Project
    Disco 2 M57 Extra Cab Project
    Foton Tunland Cummins ISF
    Disco 1 3 door 4.6 V8 Auto
    RRC V8 Auto "Classic" Softdash
    RRC 300 TDI Auto
    Disco 1 TD5 Auto Buggy
    Disco 1 300 Tdi Auto Ute
    SAME Explorer 70HP 4x4 Tractor plus Nell Loader
    Subaru GDA WRX
    Triumph Bonneville SE
    Yamaha TTR250
    SYDNEY -in the shire.....
    what radio is it?
    most need some kind of radio keys to hook on the clips down the sides of the unit and release it from the carrier.....
    some of the later ones have allen key screws in them....usually 3mm.
    do you have a picture of it?
    i might be able to tell you what tools you may need....
    i may even have the tool.....
    or a model number i may be able to look up on the net?
    Defender200Tdi Guest
    It's most likely just a Eurovox radio re-badged as Landrover. These are fitted locally, not in the UK before import.
    It's a pretty poor auto elec place if they don't have the key to remove the unit. I'd suggest taking it to a different car audio installer.
    However, in most cases a thin strip of steel pushed into each slot on the side on the radio facia will release the clips, allowing the unit to slide out.
    Paul [img]style_emoticons/<#EMO_DIR#>/biggrin.gif[/img]
    Bathurst NSW
    Hi guys, thanks for the help, i only took it to this guy cause the other one was booked out and i wanted it for the weekend as i was going to Newcastle for LROC driver training. Marcos is sick however so that wont be happening. I will book it into the other place, who installed my UHF, and get them to do it.
    I am pretty sure its the Eurovox one as mentioned above. Matt
    South Yundreup,WA.
    When I removed my Disco one 97Tdi it required the Eurovox tool as it was different to most others. The Eurovox had two small holes either side of the radio and used a U shape tool to unlock and remove. You can also use acouple of thin long allen keys releasing one side at a time. The other type like what was in my Defender uses the standard blade shaped tool down the side.
    Brisbane Australia
    You will see a thin slot on each side of the front panel, cut 2 pieces of panel steel about 50mm long push them in the holes and then pull the radio out.
    ive got some eurovox radio keys.....
    May 2003
    On The Road
    removed a few radios have we Zook??? :wink:
    Moses Guest
    HTH
    LRH
    Yep. Done it myself using drill bits and allen keys.... Well, who do you know has 4 allen keys all the same size?? 8O
    The trick is to get just the right size wire or thin steel rod. It needs to be a snug fit so it depresses the clips properly.
