Results 1 to 10 of 18
Thread: suspension lift seriesII disco
    Pennant Hills, Sydney
    Hi there I have a seriesII disco with the air bag suspension would like to
    do away with the air springs on the rear and add a couple of inches of
    lift any good kits out there that people have tried??I will be fitting a steel bar to the rear as the plastic bumper is held on with cable ties after a trip to the vic. high country and have a long range fuel tank as well so a bit of
    extra weight,want something good as looking at doing cape york next
    year
    Firstly, you want to keep the air suspension in the rear, it is fantastic and often very handy. I have SLS & ACE and run a 2" lift and can run 34" Simex's no problems but run 32" MTR as everyday road tyre.
    For the front I use custom springs from Browns Springs but there are many Off-the-shelf 2" lift springs.
    For the rear I have 2" spacer blocks which fit under the SLS bags and are very easy to install. The spacers are made by Michael Samootin at 4x4Design Engineering. You can contact him at enquiries@4x4de.com.
    Michael also make many other things such as Rock Sliders and Steering protectors for the Disco II.
    Western Australia
    Adam,
    Did you change the shockies? Was there anything else that had to be modified as a result of putting the spacer blocks under the springs?
    I am considering a lift on my 94 classic.
    RichardK
    Series IV Matrix Offroad Camper following our Discovery 3 with E Diff, BAS Remap, Mitch Hitch, Uniden UHF, Codan NGT HF, Masten TPMS, Proquip Compressor Guard, ARB Winch Bar, Milemarker Hydraulic Winch, 4x4 Intelligence Rear Wheel Carrier, VMS GPS with Rear Camera,
    I use tough dog shocks all round which are longer than standard.
    The spacer blocks come in a kit with everything needed such as extended bump stops and the raiser bracket for the SLS sensor and new mounting bracket for the ABS & brake lines. This kit is specialy made for the Disco so i doubt it would work on the Rangie.
    The spacer blocks are not just blocks as you would use on a body lift but are engineered and laser cut so that the bottom of the air bags click into them. (not a very good explanation but best I can do :? )
    Stevo,
    Here is a pic which shows how much lift I have still with the air bags. This is running 34" tyres. The good thing about the air bags is that no matter how much weight you put on the back they just pump up more to keep the ride level.
    Western Australia
    Thanks for that Info, you explained it well.
    RichardK
    Forty minutes closer to the hills in a house the bank is kind enough to let me live in
    Hey Walker - any chance of a close up of your steering guard and front recovery points? I need to source one for my S1 Disco and I'm trying to get a look at everything available.
    Mac
    thanks Adam for the info will look into that as well, sounds like that might be the go
    slunnie
    pm slunnie from this forum overlander and ask him for advice. He custom made his 4" with 35 inch Simex and did an awesome job. he knows his stuff.
    Andy
    Gold Coast, Qld
    I'll second that Walker. Got the same winch bar as you and struggling to find suitable recover points other that the eyes on the bar itself. Looks like you have a couple of shackles attached somewhere. Also would be keen to hear if you have any points at the back other than the tow hitch. I have considered sticking some holes through the rear bumber to find some points but haven't got round to removing it yet. Any tips or help appreciated.
    Mick
    '99 Manual TD5 D2.......heap of money spent on it and it has ended
