Page 1 of 6 123 ... LastLast
Results 1 to 10 of 59
Thread: Engine power loss/limp mode TDV8
    Sep 2010
    Dunsborough
    This is a first for me. Just arrived in Shark Bay yesterday after an 850km drive up from Perth and as we slowed down to town speeds the 'engine systems warning' came up on the TFT screen and the car went into limp mode.
    Earlier in the drive, both me and my co-driver noticed that sometimes, when we weren't using cruise control, the engine power would suddenly and intermittently appear to drop then surge back up again. Most disconcerting.
    Yet this problem wasn't apparent while using cruise.
    I called the service manager at Barbagallo Land Rover, who said to start and stop the engine three times, that seems to have killed the screen alert for the time being, although I haven't driven the car anywhere yet.
    Curious, has any other FFRR owner had a similar issue?
    Another minor thing: fuel consumption on the drive seems to have been much higher than I would expect, at 10.6l per 100. We weren't towing anything, although we were well loaded up with 4 adults and gear, sitting on 110 to 115 all the way, and there was a stiff cross wind, so I guess that may explain it.
    NSW SW Slopes
    Was there any exhaust smoke at the time and has the secondary turbo drain fix been done?
    It sounds like a sticky primary turbo actuator.
    Adelaide - Torrens Park
    Check the top intercooler hoses for splits.
    Quote Originally Posted by GregMilner View Post
    That is pretty consistent with what I get out of my 07.
    Brisbane, Queensland
    Same here. It drops back to 9lt/100 if I stick around the 100kmh
    L322 tdv8 poverty pack - wow
    Track Trailer ARN 200-117
    REMLR # 137
    Sep 2010
    Dunsborough
    No smoke Graeme. Can't remember if the turbo drain fix has been done. It was in for some work at the dealer last year to fit some piping to fix a problem where the pan under the engine was collecting oil, but I can't remember if that was to do with the turbo. I'll get them to run some error code checks when we get back in a week or so. (Currently at Dirk Hartog Island, but left the car in Denham and came over by boat.)
    Sep 2010
    Dunsborough
    Quote Originally Posted by BigJon View Post
    I normally get about 8.5 to 9 at 110kmh on the highway, with the 8 speed gearbox. I'm guessing a full load and stiff breeze might account for the extra use. But it could also have something to do with the turbo, if there is in fact a problem with it.
    I generally do a quick calc (litres/odo km) when I fill up to work out what I've used per 100km. The vehicle computer always shows better economy by 0.5 to 1.0/100km. Given the speedo over reads the speed on all vehicles which might also slightly result in the odometer under reading, I'm wondering if the computer might be right.
    According to the computer the best I've got from a hw run empty is 8.5/100km.
    The mechanic recently put a dose of Revive engine/turbo/EGR cleaner through my motor after I complained of reduced fuel economy and a bit of black smoke on acceleration. I checked the upper IC hoses (replaced 18 mths ago) but couldn't find any sign of a split. After the treatment I t has noticeably more power and runs quieter. The economy seems better but I need to do a few tank fulls to be sure.
    REMLR # 137
    NSW SW Slopes
    Quote Originally Posted by rar110 View Post
    The CCF has individual settings for odometer, speedo and fuel consumption calculations. LR set the speedo to use the +3% +2 kph formula for our vehicles whereas the odometer is based on the recorded tyre size. I changed my D4 to use the +0% +2 kph alternate formula and set the tyre size to what is fitted, being slightly oversize on standard, with the result that the speedo reads 1 kph fast at 110 kph and the odometer still spot-on using the freeway 5 km checks. I also changed the fuel consumption factor from +7% to -6% to get it about right most of the time.
    So is the odometer or computer calculated fuel use more accurate on standard 255/55/19 tyres?
    REMLR # 137
