Results 1 to 10 of 36
Thread: Engine Oil for a 3.0 TDV6 2010
    Jan 2015
    Tasmania
    Hi guys what is the spec and where can I get oil from for the 3.0 TDV6 2010 Castrol 5-30 edge Professional is what Castrol web site states but Repco and Super Cheap here don't stock it he recommended a Penrite 5-30 not sure on it.Any help would be great as Repco has 30% this weekend for RACT members.
    Putting it it perspective...
    Save 30% on oil... Excellent..
    But if it's wrong; and engine is $15k
    Feb 2012
    Canberra/Melbourne
    I was in a BP the other day and they had all the Castrol Oils. I was just about to put the same post up for my V8.
    [SIGPIC]
    2012 LR Defender 90 (BERT) Gone
    2012 Husqvarna WR 300
    2014 FPV F6 Gone
    2005 D3 SE V8
    2011 D4 V8
    2016 Moto Guzzi California Audace.
    Feb 2012
    Heddon Greta NSW
    The Penrite 5w30 is fine as I have been using it now for 20,000km, it meets all the spec's and I rang Penrite to confirm.
    Jan 2015
    Tasmania
    From the Penrite website:
    ENVIRO+ C-4
    Full synthetic, SAE 5W-30, low SAPS (Sulphated Ash, Phosphorus and Sulphur) engine oil. It meets the requirements of ACEA C4. Applications include late model Nissan Pathfinder, Navara and X-Trail and many Renault and Samsung vehicles that require the Renault RN 0720 specification. May be used where ACEA C1 is required such as in some Landrover and Jaguar vehicles.
    Key Specifications: ACEA C4, Renault RN 0720, Ford M2C934-B (level)
    Product Codes: EPLUSC4001, EPLUSC4005, EPLUSC4010, EPLUSC4020, EPLUSC4205
    Jan 2008
    ACT
    Been using the penrite for the last 3 oil changes...was blowing smoke for the first change then stopped completely after the second change. Get it at Auto pro, and they do all the filters as well...
    All my post was eluding to is please confirm the oil you purchase is suitable for your engine
    Jan 2015
    Tasmania
    No harm Tombie, I am just trying to find an oil suitable for this vehicle but this engine is just a little more advanced than my previous 3.0L Patrol. I used to use Penrite for my JEEP 2.8CRD but the patrol was just Caltex Delo 400 the biggest thing I'm confused over with this model is the "ACEA C1" spec. This is the first time I will be servicing it after purchase so just wanting to get it right, only 85,000klms, the last 2 invoices from previous owner that were supplied didn't stipulate the oil used.
    NSW SW Slopes
    The 934 spec oil only has to be used if the vehicle is fitted with a DPF, which the very first batch of 3.0 MY10s were. Ford WSS-M2C-913-C is the current spec for non-DPF engines. Castrol Magnatec Professional A5 5W-30 (A5/B5 WSS-M2C-913-C) is what I use.
    Note: corrected spec on the Magnatec.
    Jan 2015
    Tasmania
    So how does one check if they have a DPF Filter?
