Results 1 to 6 of 6
Thread: Rear tow cover template
    Nov 2012
    Muscat, Oman
    Does any one have a template for trimming the rear tow cover so that in can be fitted with Mitch hitch in place?
    I'd like to tidy things up back there
    TIA
    I just started cutting
    It's not too difficult.. Just cut it completely in halves then hold it up alongside and mark out what needs removing.
    NSW Far South Coast
    Thats the way I did mine!
    LRD414's Avatar
    Oct 2014
    Cut in half first
    Same here. Cut in half and then work the shape required. I finished off with a rasp.
    You can see the centre cut in this photo. It's only a small finger that you want to keep going across above the hitch. It's tight at about 10mm wide.
    Link to my D4 Build Thread
    D3 2005 V8 Petrol
    Oct 2014
    Boronia (Victoria)
    Smile
    I finished off the cut out with pinch weld from Clarke Rubber. Just tidies up the unavoidable rough edges. :
    Nov 2012
    Muscat, Oman
    Ahh that explains it
    Thanks for the pointers guys. It had completely escaped me that your covers weren't one piece any more.
    Now it looks doable
