So this arvo I put an oscilloscope on the output of the crank angle sensor.
This is what it looked like.
From the left (disregarding the first spike), the first pulse with the different shape is the one that sets up the timing. The reluctor ring has a missing tooth (intentional) to to identify TDC on no. 1 cylinder. Those pulses are 10 degrees apart - there's 35 pairs of teeth (don't forget there's a missing tooth to make up the 36 needed).
From the workshop manual:
The output signal from the CKP sensor is obtained from the magnetic path being made and broken as the reluctor ring teeth pass the sensor tip. The reluctor ring has 35 teeth and one missing tooth spaced at 10° intervals. The missing tooth is positioned at 20° after TDC.
