Results 1 to 10 of 15
Thread: Disc pads and rotors - opinions
    May 2010
    Mindarie, Western Australia
    My Rangie is in need of new disc rotors and pads all round and I'm trying to decide between stock solid rear discs and vented front discs vs the cross drilled and grooved aftermarket variety. If I was only doing bitumen driving the cross drilled and grooved would be almost a "no brainer" but I'm concerned at picking up mud, sand and small rocks in the drilled and grooved discs.
    Has anyone had any first hand off road experience with the drilled and grooved discs? Do they suffer from picking up any dirt and rocks, or am I just being paranoid?
    Gary
    Feb 2010
    Townsville, QLD
    I've got drilled and grooved rotors on mine. No issues. I had a pebble stuck behind a front rotor (between the guard/cover and the rotor) on my cape trip but it came out easy enough and caused no damage (not due to the type of rotor).
    They are noticeably better.
    EBC pads are dust mongers. I thought they were great until I realised that I wash my Rangie too often to get noticeable brake dust on the wheels. Just get bendix pads instead.
    Keithy
    99.87 MB
    I've run plain, slotted, and slotted and dimpled.
    Never had issues with debris in the slots and dimples.
    I would avoid cross drilling like the plague. I've you've seencross drilled rotors with multiple fractures radiating from each cross drill, you'd also never consider them again. To be honest, I also don't think that cross drilling or dimpling properly/completely swipes the pads and so are just a bit of brake bling. I do however think that slotting is good. The rotor that I do like is the Dba rotors with slots. I would run these or plain factory ones.
    For pads, Bendix for me also. Work well. even when they're hot and they're not notably dusty. Despite the engineering science behind brakes, I think the pads make a far greater difference to braking than the rotors.
    Slunnie
    May 2009
    Ballan
    Bendix pads for sure, I had DBA slotted on my D2 and they were fine. When I ordered my DBA slotted rotors from Repco (they were on sale) I was offered cross drilled for the same price as DBA has some in stock, the guy in Repco said don't use cross drilled on 4wds, don't know why but he muttered something about they can't be machined
    there is absolutely nothing wrong with std vented... if it ain't broke, don't fix it.
    Hoo-Roo,
    Dave.
    Feb 2013
    Gosford, NSW, Australia
    HI
    I used the ECB Green Stuff Kevlar pads on my 99 and they were great around town but they faded very badly on a long hill descent.
    Personally I will probably go for ceramic pads next time, but if the vast majority of your driving is around town, the the Bendix pads are a good choice
    Steve
    FWIW...Several years ago I bought a set of Brembo vented rotors for the front...about $50 each plus Bendix pads. DbA actually warn against using cross drilled for all but street use due to the cracking mentioned by Slunnie. So far (50k km) pads are 50% worn and rotors still well within spec. I have thought about slotted rotors. They are demonstrably more efficient especially operating heavy loads /towing etc.
    May 2010
    Decision made. Today I will be ordering a set of 4 DBA rotors and Bendix 4WD pads al round. Rotors will be the standard rotors. But like most things here in Perth I will have to wait a few days before the parts arrive from Eastern states. WA - Wait Awhile 😉. A bit of luck they should arrive for fitting over the weekend.
    Thanks for your input guys....much appreciated!
    Gary
    Jul 2014
    Good choice.
    2000 4.6 HSE Alveston red
    2007 307 xse peugeot
    1974 xj6l jaguar
    garybrook Guest
    Quote Originally Posted by Hoges View Post
    Thanks Hoges,
    For what's it's worthwhile, I recently bought and installed the same set of disks and pads, specifically from reading the experience and opinions of other 4WD users, not just RR P38 owners. Broadly, several said these current Brenbo disks are rather harder material, so I tried them as my previous owner told me that the disks wore out rather quickly, but the Girling pads weren't, even though they were very 'dusty'. Some prefer the dual compound pads and others don't, so ....
    I haven't done a lot of mileage (5,000km) on this combination, yet but they've taken a long time to bed the in. When they are cold, you need to use more pressure than I was expected, but I'm a new owner for P38s. When they get warm they are better. After a few weeks of using them I started to use them harder and found that they have plenty of power, yet not much feedback. I'm not sure that the brakes on mine are as good as they should, and the rear pads have not yet bedded in much at all, despite new fluids (properly) so I could have a line blockage or sticky pins.
    At the moment I have a kit for the modulator, new hoses (5), caliper piston/seal kits and pins/seals as nothing has been done on rebuilding the brakes since new. I'll give some feedback when that work is done.
